Cleaned my EGR valve - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jdydiesel, this thread has received 19 replies and been viewed 5964 times.
post #1 of 20 (permalink) Old 04-04-2008, 09:44 PM Thread Starter
Dually Club #3
jdydiesel's Avatar
I was alittle board this morning so I did some preventive maintenance on my truck. I pulled the EGR valve and cleaned it. Check out the pictures of before and after. I noticed that I didn't have any moisture in down inside the cooler but the soot was oily right below the valve, is this due to the 2 stroke oil I run or is it normal to have this. Also how does the valve look after 43,000 miles, does it have a normal apperence or is this alot of soot compared to normal?
Name:	EGR preclean 2.JPG
ID:	15341   Click image for larger version
Name:	EGR preclean 4.JPG
ID:	15342   Click image for larger version
Name:	EGR cleaned.JPG
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #2 of 20 (permalink) Old 04-05-2008, 01:20 AM
It really doesn't look too bad. Did you clean the intake manifold opening, the MAP sensor hose, and the EBP tube as well? These are components that can plug also.
Mark
'06 F250, CC SB ESOF FX4 Lariat 3.73LS, 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto valve; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco next; then DashDaq
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
imported_bismic is offline
post #3 of 20 (permalink) Old 04-05-2008, 01:27 AM Thread Starter
Dually Club #3
jdydiesel's Avatar
No I didn't. This is the first time that I have done this so I didn't know what else needs to be cleaned. Where is the map sensor hose and the EBP tube?
Jason
post #4 of 20 (permalink) Old 04-05-2008, 01:37 AM
I've not done it myself, but have read some on it. I will try to post the links I have been reading. Until I can find them, here is a TSB:
Coking (carbon) Deposits in Turbo and/or EGR Valve:
Coking deposits are usually a build up of unburned fuel or oil in the exhaust system and related components (valves, turbo, EGR valve). This can be caused by poor fuel quality, overfueling/leaking injectors, idling for excessive periods of time (especially in cold ambient temperatures), low engine operating temperatures, injection timing (calibration) or oil consumption. Unburned fuel usually appears as white smoke, but over time the coking condition can result in excessive black smoke. Coking deposits can plug the EBP sensor tube, foul the EBP sensor, cause the EGR valve to stick open, block the EGR cooler, plug the MAP (boost) sensor hose, or cause the variable turbo vanes to stick open (no power/boost) or closed (excessive backpressure, black smoke, popping noise, bucking). The cause of the coking issue should be identified before replacing parts to prevent reoccurance. If poor fuel is suspected, use Stanadyne Performance or Motorcraft PM-17-A Cetane Boost. TSB 06-4-12, 06-23-16.
Mark
post #5 of 20 (permalink) Old 04-05-2008, 01:39 AM
Here is what I have found:
MAP - Manifold Absolute Pressure
The MAP port is on the intake manifold. The hose comes off of that port.
http://dan.prxy.org/Truck/6L_bible_h.../Page_038.html
http://dan.prxy.org/Truck/6L_bible_h.../Page_063.html
http://www.motorcraftservice.com/pub...6/A0065602.gif
http://www.motorcraftservice.com/pub...4/A0065603.gif
EBP Exhaust Back Pressure
http://dan.prxy.org/Truck/6L_bible_h.../Page_058.html
http://dan.prxy.org/Truck/6L_bible_h.../Page_009.html
http://www.motorcraftservice.com/pub...1/A0075877.gif
Mark
post #6 of 20 (permalink) Old 04-05-2008, 01:49 AM Thread Starter
Dually Club #3
jdydiesel's Avatar
Thanks for those images, they are great and I will be doing some more cleaning tomorrow.
Jason
post #7 of 20 (permalink) Old 04-05-2008, 01:51 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
that looks normal and has nothing to do w/ any 2 stroke oil.
2003 F250 "Pulling Truck"
hhrecovery is offline
post #8 of 20 (permalink) Old 04-05-2008, 01:55 AM Thread Starter
Dually Club #3
jdydiesel's Avatar
So I shouldn't have to change anything then right?
Jason
post #9 of 20 (permalink) Old 04-05-2008, 01:57 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
nope the EGR valve looks like it is in good shape.
post #10 of 20 (permalink) Old 04-05-2008, 01:59 AM Thread Starter
Dually Club #3
jdydiesel's Avatar
Great thanks. I will clean the MAP sensing tube and the EBP tube tomoorow and then probably clean this stuff about every 20K miles.
Jason
