EGR Delete Advice, and Warning - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by NCfarmboy, this thread has received 32 replies and been viewed 10028 times.
post #1 of 33 (permalink) Old 04-09-2008, 01:19 AM Thread Starter
Haulin' Hay
NCfarmboy's Avatar
Lightbulb EGR Delete Advice, and Warning
Ok, so I've learned a few things in the past week or so concerning the EGR Valve delete on these 6.0's. My brother and I both drive SRW F-350's-mine is a 2004, and his is a 2005. Both have blown stock headgaskets, and now have ARP studs. He runs an SCT custom tuned by Innovative, and I run an Edge Platinum (yes, he can smoke me).
Well, after his EGR Cooler went bad, we decided to block the Exhaust gasses from entering his new EGR Cooler. The tech that was doing the work did it on the side, and agreed to block it off using a freeze plug.
I also wanted to block off the exhaust gasses from entering my EGR cooler, but I ended up cutting my pipe, and welding it up. I then took the other half of the pipe, and welded it, using the stock clamp to seal up the EGR cooler.
Today, my brother had to replace his turbo, because the freeze plug melted and trashed the turbo. Fortunately, it wasn't too big of a deal, because he found another stock turbo for next to nothing.
I just wanted to pass this information along for those wanting to block off their EGR Cooler. I think it's a great thing to do-- just be careful what you use to do it.
NCfarmboy is offline
post #2 of 33 (permalink) Old 04-09-2008, 01:30 AM
Dually Club #3
jdydiesel's Avatar
This is the second time I have heard someone scraping there turbo because of a freeze plug. I would think that there is a batter way of doing this that won't compromise the other componants.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #3 of 33 (permalink) Old 04-09-2008, 01:35 AM
El Conquistador
Thanks for the heads up farmboy.:Thumbup:
Mike
2004 F 250 Lariat 4x4 6.0 PSD SOLD
January 2004 Born on Date
-4 inch Magnaflow turbo back exhaust, No Kitty
-SCT by DJ Diesel Performance
-Quadzilla Commander
-Black 17x9 Moto Metal 951 wrapped in 295/70R17's Nitto Terra Grapplers
-Accufab Intake Elbow
-AFE Replacement Dry Filter
The Words "Chevy" and "Power" do not belong together laugh
Mlhaynes8302 is offline
post #4 of 33 (permalink) Old 04-09-2008, 01:42 AM
why not just use a plate to block it like elite has?
05 F-250 FX44"superlift, 35" pirelli scorpion ATR"S, sirius satellite radio, 1 sony 10" with 1k watts. sct with spartan and Doug's tunes, bullydog outlook, coolant temp, Egrcooler delete, coolant filter, 4" exhaust to 5" stacks, B&W gooseneck hitch, limo tint, ARP studs. AFE stageII intake with PG7, VIPER 5900SST
RIDIN' DIRTY member #23
Bomb Squad member #49
Running motor and trany with all wires, computers, ic, programmer and outlook will be forsale! PM with offer.
stacks is offline
post #5 of 33 (permalink) Old 04-09-2008, 01:47 AM
********* and Mafia #90
Bcarriveau's Avatar
this is what mine will look like thanks to extended power..
I like posting pictures.
100K miles on 4/7/2010
2005 F250 FX4 Supercab Shortbed
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #6 of 33 (permalink) Old 04-09-2008, 02:03 AM Thread Starter
Haulin' Hay
NCfarmboy's Avatar
Thanks for posting... That's exactly what I did to mine.
post #7 of 33 (permalink) Old 04-09-2008, 02:06 AM Thread Starter
Haulin' Hay
NCfarmboy's Avatar
That's certainly alot better option than a freeze plug - that's for sure. I just welded mine because I have a welder, and it was free for me.
post #8 of 33 (permalink) Old 04-09-2008, 02:08 AM
Bcarriveau's Avatar
did you just wire weld it or did you tig it? they are too different materials and should have been braised(tig welded)
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #9 of 33 (permalink) Old 04-09-2008, 02:13 AM
flyin05's Avatar
Send a message via AIM to flyin05
i did it by just welding metal over the hole and cutting the scoop out..not issues yet
2009 trailblazer ss
Sold-2005 F250 4x4 ext cab. sct tuned bt DJ's, afe stage 2 intake, 58mm turbonetics turbo, cobalt series egt, boost, fuel pressure, 5in exhaust, head studs, egr complete delete by jpscustoms and myself
06022008-usmc
flyin05 is offline
post #10 of 33 (permalink) Old 04-09-2008, 02:22 AM Thread Starter
Haulin' Hay
NCfarmboy's Avatar
I MIG welded it. Brazing is different than TIG welding. I'm confused about what you mean when you say they are 2 different materials. I used a grade 8 washer to fill the hole in the Up pipe, and ground the welds down smooth. Thanks!!
