Hey guys, I just got this OASIS report...and I would like your opinions on it. I'm not going to reply yet....I just want honest opinions.
OASIS RESULT:
1FTWW33P53ED37385
USA
EN
07/27/2009
00:14:24
FCXWS446
© Copyright 2002-2009 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
F2 ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L FUEL INJECTORS, REFERENCE 09-07-11
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/20/2003 BUILD DATE
05/16/2003 SALE MILEAGE
00597
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0707 - EXPIRED
STANDARD DEDUCTIBLE: 50 USD
OWNER NAME: LILA JO TATE
OPTIONS:
EXPIRATION DATE: 09/20/2008
DISTANCE: 100,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 04241
ESP CONTRACT START DATE: 09/20/2003
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
09/02/2008
DEALER: Tipton Motors, Inc.
WARRANTY CLAIM NUMBER: 075260 ODOMETER: 030446M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9E527ECRM NOZZLE ASY-FUEL INJE 002 6005F 42 DOES NOT OPERATE PROPERLY
5C3Z 6F089BA ACTUATOR ASSY 001 6005F1
W300012 002 6005F1X1
3C3Z 6B898AA GASKET OIL RETURN LI 001 6005F2
4C3Z 9J460A SENSOR ASY EGR PR VL 001 6005F6
000 6005F8
000 6005F12
000 6005F13
000 6005F14
000 6005F20
000 6005F25
000 6005F33
000 9527AT
000 12650D9
30446 RUNS ROUGH AT COLD START AND NORMAL TEMP. CODES P0401 P1328. RAN OASI S FOR TSBS OR SSM, TSB 07-5-4. RUNS ROUGH ON COLD START UP. CHECKED VEH FOR LATEST CALIBRATION VEH AT HIGHEST CALIBRATION LEVEL. INJ ARE BUZZING AT SHU TDOWN. PERFORMED POWER BALANCE TEST AT NORMAL ENG TEMP. INJ #1, #3 MISFIRE, REPLACED. CLEAR CODES, ROAD TESTED. ENGINE LIGHT ON. CODE P0401 EGR NO FLO
09/02/2008
LABOR OP
CONDITION CODE
CONDITION DESC
YC3Z 7G360AA MOTOR ASY 001 7453D 28 OPEN CIRCUIT
000 7453D45
000 MT7G360
30446 TRANSFER CASE MOTOR SHORTED OPEN CHECKED 4X4 FOUND TRANSFER CASE MOTO SHORTED OPEN REMOVED AND REPLACED TRANSFER CASE MOTOR ACTUATOR
09/02/2008
LABOR OP
CONDITION CODE
CONDITION DESC
XF2Z 14018AD SWITCH ASY DOOR WARN 001 27406B 42 DOES NOT OPERATE PROPERLY
000 27406B5
30446 LEFT REAR DOOR AJAR SWITCH SRUCK OPEN REMOVED LEFT REAR DOOR TRIM PAN EL TO ACCES AND REMOVED DOOR LATCH AND REPLACE DOOR AJAR SWITCH
09/02/2008
LABOR OP
CONDITION CODE
CONDITION DESC
YC3Z 2267BA TUBE ASY-RR BRAKE 001 ADD D8 FAILED GASKET/SEAL
YC3Z 2268CA TUBE ASY-RR BRAKE 001 MT2267
PM 1C BATTERY ASY 002
30446 VERIFIED CONCERN. FOUND REAR BRAKE LINE LEAKING FLUID. REPLACED BRAKE LINE. BLEED BRAKES.
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 12 5T01 031801 3C3Z 9F836 BA A25 42 5333
AWS Claim Key: 7860013 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-AUG-2004 Doc #:15001802
Cust Comments: A25 CRUISE CONTROL WONT ENGAGE
Tech Comments: INSPECTED CRUISE CONTROL SYSTEM AND FOUND CRUISE CONTROL BUTONS WITH INTERNAL OPEN. REPLACED CRUISE CONTROL BUTTONS
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 12 2H01 031202 * 6K786 * D50 42 5333
AWS Claim Key: 7860012 Trx Code: 2 Labor Hrs: 1
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-AUG-2004 Doc #:15001807
Cust Comments: LACK OF POWER
Tech Comments: INSPECTED FOR LACK OF POWER AND FOUND TURBO HOSE CLAMPS BROKEN. REPLACED TURBO HOSE CLAMPS AND CHECK OK.
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 12 7S06 030008 3C3Z 12B637 BA E29 42 5333
AWS Claim Key: 7927050 Trx Code: S07 Labor Hrs: 3.5
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-AUG-2004 Doc #:15001801
Cust Comments: E29 CHK ENGINE LIGHT ON
Tech Comments: FOUND GLOW PLUG HARNESSS BURNT. REPLACED GLOW PLUG HARNESS AND CHECK OK.
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 16 6P07 011202 2C3Z 7811586 CAB N30 07 9337
AWS Claim Key: 9035611 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-DEC-2004 Doc #:15680403
Cust Comments: OVER HEAD CONSOLE DOORS LOOSE
Tech Comments: INSPECTED OVER HEAD CONSOLE AND FOUND DOORS HAVE POOR FIT. REPLACED OVER HEAD CONSOLE DOORS.
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 16 7H09 120303 4C3Z 19860 AB C05 42 9337
AWS Claim Key: 9109304 Trx Code: E83 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-DEC-2004 Doc #:15680405
Cust Comments: STATES A C NOT COOLING
Tech Comments: FOUND LEAK AT THE ACCUMULATOR EVAP CORE. REPLACED TO CORRECT.
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 17 7H09 120303 4C3Z 19860 AB C02 42 10292
AWS Claim Key: 9423713 Trx Code: E89 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN-2005 Doc #:15891101
Tech Comments: INSPECTED A C SYSTEM AND FOUND EVAPORATOR LEAKING. REPLACED EVAPORATOR, DRIER ACCUMULTOR, ORFICE TUBE, FLUSH SYS EVACUATE AND RECHARGE.
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 18 7H06 1203XX 1W1Z 19E889 BB C05 42 11059
AWS Claim Key: 9792498 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2005 Doc #:16055301
Cust Comments: A C NOT COOLING
Tech Comments: INSPECTED AC SYSTEM AND FOUND LEAKS AT EVAPORATOR CARE OFFICE TUBE LINK AND ACCUMILATOR LINK REPLACED O RING
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 19 7H11 120305 4C3Z 19D850 CA C05 42 11641
AWS Claim Key: 10397004 Trx Code: E83 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-MAR-2005 Doc #:16309501
Cust Comments: C05 AC NOT COOLING
Tech Comments: FOUND AC MONIFOLD HOSE LEAKING FREON REPLACED TO CORRECT CONCERN.
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 19 7B02 140201 4C3Z 10346 AA G29 42 11641
AWS Claim Key: 10397003 Trx Code: E83 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-MAR-2005 Doc #:16309503
Cust Comments: D03 WONT CRANK
Tech Comments: FOUND ALTERNATOR NOT CHARGING, REPLACED ALTERNATOR TO CORRECT.
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 34 * * * * * * * 18543
AWS Claim Key: 14006626 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2006 Doc #:030360A
Cust Comments: PERFORM OPEN FSA #06E17
Tech Comments: REPROGRAM MODULES PER 06E17.
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 34 7G03 120202 4C2Z 19A706 AA C05 42 18543
AWS Claim Key: 14006628 Trx Code: E83 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2006 Doc #:030360F
Cust Comments: C S A C DOESNT WORK ON LOW SPEED,2ND AND 3RD SPEED ARE THE SAME
Tech Comments: FANS ONLY WORK ON HIGH AND NOT LOW OR OTHER SPEEDSRESISTOR MELTED AND CONNECTOR BURNT, REPLACED BOTH
AWS Claim Key: 14006627 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2006 Doc #:030360B
Cust Comments: PERORM OPEN FSA#59B01
Tech Comments: TEST DROVE PER 59B01.
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 61 3Y11 070701 YC3Z 7G360 AA P82 28 30446
AWS Claim Key: 16235976 Trx Code: 0707D Labor Hrs: 1.2
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-SEP-2008 Doc #:075260C
Cust Comments: VEHICLE WONT ENGAGE INTO 4 WHEEL DRIVE HI OR LOW
Tech Comments: 30446 TRANSFER CASE MOTOR SHORTED OPEN CHECKED 4X4 FOUND TRANSFER CASE MOTO SHORTED OPEN REMOVED AND REPLACED TRANSFER CASE MOTOR ACTUATOR
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 61 5V05 060603 YC3Z 2267 BA L63 D8 30446
AWS Claim Key: 16235977 Trx Code: 0707D Labor Hrs: 1.5
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-SEP-2008 Doc #:075260I
Cust Comments: BRAKE FLUID LEAKING FROM REAR BRAKE LINES
Tech Comments: 30446 VERIFIED CONCERN. FOUND REAR BRAKE LINE LEAKING FLUID. REPLACED BRAKE LINE. BLEED BRAKES.
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 61 7C01 011404 XF2Z 14018 AD L19 42 30446
AWS Claim Key: 16237558 Trx Code: E81 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-SEP-2008 Doc #:075260E
Cust Comments: DOOR AJAR AND INTERIOR LIGHTS STAY ON AT TIMES
Tech Comments: 30446 LEFT REAR DOOR AJAR SWITCH SRUCK OPEN REMOVED LEFT REAR DOOR TRIM PANEL TO ACCES AND REMOVED DOOR LATCH AND REPLACE DOOR AJAR SWITCH
1FTWW33P53ED37385 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-MAY-2003 20-SEP-2003 152122 USA 61 2E03 030402 3C3Z 9E527 ECRM D02 42 30446
AWS Claim Key: 16241905 Trx Code: S07 Labor Hrs: 7.3
Dlr Cd-Sub Cd: 04421 - * Name: TIPTON MOTORS, INC. Ph: 956-3505600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-SEP-2008 Doc #:075260B
Cust Comments: VEHICLE WILL HARDLY MOVE RUNS ROUGH UNTIL ITS WARMED UP, FORD ESP EXTRACARE DIESEL
Tech Comments: 30446 RUNS ROUGH AT COLD START AND NORMAL TEMP. CODES P0401 P1328. RAN OASIS FOR TSBS OR SSM, TSB 07 5 4. RUNS ROUGH ON COLD START UP. CHECKED VEH FOR LATEST CALIBRATION VEH AT HIGHEST CALIBRATION LEVEL. INJ ARE BUZZING AT SHUTDOWN. PERFORMED POWER BALANCE TEST AT NORMAL ENG TEMP. INJ #1, #3 MISFIRE, REPLACED. CLEAR CODES, ROAD TESTED. ENGINE LIGHT ON. CODE P0401 EGR NO FLOW. REMOVED
OASIS RESULT:
1FTWW33P53ED37385
USA
EN
07/27/2009
00:14:24
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
ARN MESSAGES
WARRANTY START DATE
00597
EXTENDED COVERAGES
0707 - EXPIRED
OPTIONS:
DISTANCE: 100,000
TOWING: 0 USD
09/02/2008
LABOR OP
CONDITION CODE
CONDITION DESC
000 6005F8
000 6005F12
000 6005F13
000 6005F14
000 6005F20
000 6005F25
000 6005F33
000 9527AT
000 12650D9
09/02/2008
LABOR OP
CONDITION CODE
CONDITION DESC
000 7453D45
000 MT7G360
09/02/2008
LABOR OP
CONDITION CODE
CONDITION DESC
000 27406B5
09/02/2008
LABOR OP
CONDITION CODE
CONDITION DESC
