ITP regulated return help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mpropst, this thread has received 23 replies and been viewed 2927 times.
post #1 of 24 (permalink) Old 08-23-2009, 12:20 AM Thread Starter
Between the rain I have been installing an ITP regulated return in my 03 6.0 Excursion. The install has gone very smooth except for the port on rear of the drivers side head. Everything I read said the fitting was a 6mm Allen, mine was a Torx. Has anybody else had this bolt be a Torx rather than an Allen?
My second problem was when I went to install the SS line from the back of the head. There is a channel cast into the head right in front of the hole. It appears as though the fuel line should ride in the channel, but I am having trouble getting it to fit. Has any body else had this problem, or am I odd man out with the heads on my 6.0?
Thanks for the help.
2003 6.0 Excursion, SCT by ID, 4.5 ICON, 35" XTerrains on XD Hoss's, ARB rear, OUO traction bars....
mpropst is offline
post #2 of 24 (permalink) Old 08-23-2009, 12:38 AM
NGHTRGR's Avatar
Both of my bolts were allen's. And my lines went through the channel. Then again I did mine when my heads were off doing studs. Hope you get it sorted out.
Black 05 Excursion -MBRP T-Back minus kitty, Airaid w/Zoodad, FS2500, Coolant Bypass, ATS Headstuds, ITP Reg Rtn, Full EGR Delete, DFUSER Light Harness, Keystone Heat Extractor Hood 2 Tone, CCV Reroute, 4-6" lift, 35" MT Baja MTZ's on Classic Locks, SCT X2 w/Innovative Extreme Race
NGHTRGR is offline
post #3 of 24 (permalink) Old 08-23-2009, 12:55 AM Thread Starter
Thanks, as long as I know they will fit, I'll just lose some more blood. I should have waited until I did studs, but I got impatient to do the fuel system.
Thanks
mpropst is offline
post #4 of 24 (permalink) Old 08-23-2009, 01:02 AM
I spent about 4 hrs getting that line in. It is a B**CH!!!!!!!
Then I took and tweeked it a little and it went in.
I did it over two days. I got thedriver side line in in the morning with a clear head and rested arms .
Good luck.
Andy 2007 4X4 F350,6.0 PSD, Lariat, CC, DRW, 9' Knapheide body, stainless steel ladder rack, SCT with custom tunes, Banks turbo back, ARP's, ITP RR, Airdog II, head coolant lines, Firestone air bags, Autometer gauges( pyro,fuel pres,water temp,boost,trans temp), CCV mod.
Work&Play is offline
post #5 of 24 (permalink) Old 08-23-2009, 01:21 AM Thread Starter
Good luck.
After cutting my hands on the downpipe for the tenth time, I felt like tweaking mine with a sledge. What did you do to tweak the line?
mpropst is offline
post #6 of 24 (permalink) Old 08-23-2009, 01:48 AM
Pappy
MOPSD250's Avatar
Ya I spent a whole day doing mine. I thought mine was a torx to but it wasn't so I ended up stripping mine out. I had to take the up pipe and loosen it then got a good chisel and gave it two wacks and she was free.(Thank God) As far as the lines fitting into the grooves I think I may have had to tweak them a lil but nothing to bad.
2003 F250 Super Duty SC 8' Bed 12V CONVERSION DONE!!!!
24V P-pump Conversion Soon
MOPSD250 is offline
post #7 of 24 (permalink) Old 08-23-2009, 03:29 AM
I can count to Potatoe
Mine was the same way, the allen key would slip out, but I was able to get a properly sized torque bit and it fit in and I was able to break the torque on it and it removed rather easily. If you need the torque bit size let me know and ill go out and get it for you, but if you got the drivers side out they are the same size. Believe me the torque bit is way easier to use with a ratchet then it is a the bull**** allen key that most people try.
dayusex is offline
post #8 of 24 (permalink) Old 08-23-2009, 03:40 AM
********* and Mafia #90
Bcarriveau's Avatar
so what is it, Allen head or torques head? two totally different slots.. One is a star and one is a hexagon ..
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #9 of 24 (permalink) Old 08-23-2009, 04:02 AM
yes but watch guaranteed the torq will fit in the allen head.
dayusex is offline
post #10 of 24 (permalink) Old 08-23-2009, 04:13 AM
Bcarriveau's Avatar
I guess i'm just looking for what the plug "actually" is.
Da Rules..Here
Dear Tequila:
The TDG TOTQ
looking for regulated return stacks Whats Been Sold 3 03-30-2009 04:45 PM
Regulated fuel return? 99fordtruckguy 1994-2003 7.3L Power Stroke 2 04-10-2008 07:26 PM
Regulated fuel return POWER STROKE 99 1994-2003 7.3L Power Stroke 5 02-25-2008 05:19 PM
Regulated Return dbunyip 1994-2003 7.3L Power Stroke 3 11-20-2007 11:32 AM
Deadhead to Regulated Return ndrorydr 1994-2003 7.3L Power Stroke 7 01-17-2007 11:01 AM
