overhead console - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by PowerstrokePower55, this thread has received 8 replies and been viewed 1851 times.
post #1 of 9 (permalink) Old 09-01-2009, 04:35 PM Thread Starter
PowerstrokePower55's Avatar
overhead console
hey fellas i was wondering my truck doesn't have the overhead console with the compass temp and mileage stuff on it. is there any way i could just buy one off ebay or somewhere and install it on my truck.
2006 F350, 6.0L powerstoke diesel,SCT SF3 Custom tunes, AFE cold air intake,swamps upgraded FICM, ARP studs, Black Onyx Gaskets, EGR Deleted, cooper discoverer S/T 35" tires, AFE 5inch straight pipe. Garret Powermax, 190cc sticks, Airdog 2. 'MERICA
PowerstrokePower55 is offline
The Following User Says Thank You to PowerstrokePower55 For this addition to TDG:
jpmaes0622 (09-01-2009)
post #2 of 9 (permalink) Old 09-01-2009, 05:01 PM
Great Question! I am standing by.
jpmaes0622 is offline
post #3 of 9 (permalink) Old 09-01-2009, 05:03 PM
SmokeCloud's Avatar
Excursions had them, see if you can find a wrecked one and get it from that.
Real Trucks Burn Diesel!
SmokeCloud is offline
post #4 of 9 (permalink) Old 09-01-2009, 05:10 PM
I know that we can get one, but will we actually be able to use it? Would we have to buy an additional computer piece or does it just plug into a port similar to OBDII?
post #5 of 9 (permalink) Old 09-01-2009, 05:16 PM
SmokeCloud's Avatar
No it should just bolt right on, you may need to splice some wires but thats about it.
The Following User Says Thank You to SmokeCloud For this addition to TDG:
PowerstrokePower55 (09-03-2009)
post #6 of 9 (permalink) Old 09-01-2009, 11:00 PM
whanner's Avatar
The scan gauge II works on our truck and give you a whole lot more info. it just plugs into your OBD II port.
http://cgi.ebay.com/SCANGAUGE-II-TRI...d=p3286.c0.m14
06' F350
I'm not a Diesel Mechanic or Expert. All posts are just guesstimations.
4" Turbo Back Exhaust, 2" lift in front,1" Lift In the Rear, EGT Gauge, ARP Studs.
whanner is offline
post #7 of 9 (permalink) Old 09-03-2009, 12:19 AM Thread Starter
i can get one i just wonder about wiring it in and such. if a truck doesnt have that console does it still have the wiring for one. that would be ideal
post #8 of 9 (permalink) Old 09-03-2009, 03:00 AM
International350's Avatar
to me the only thing my over head console does right is hold my sunglasses and tell me direction, the MPG and miles till empty is so off its rediculous. i fill up the 37 gals get over 400 miles to tank and at fill up it says 220 miles till empty lol
2004 F-350 CC LB King Ranch. Under the Hood SCT w/Innovative street tunes by Eric, Hot FICM tuned by Power Hungary, custom built 4" intake with huge afe filter, Intake elbow, 3"down pipe to 5" straight piped stack, EGR block off, Zoodad Mod, CCV mod, Complete EGR delete, The Big 3 cable upgrade w/ batts under cab, Autometer pillar guages, Boost, Trans, EGT. APR studs sitting in box ready for install
Suspension 2.5inch leveling kit. Stock King Ranch 18" rims with 33inch Nitto A/T.
Truck is now pushing 134K miles an running strong.
International350 is offline
post #9 of 9 (permalink) Old 09-03-2009, 03:33 AM
lilpooh's Avatar
The lie-o-meter is basically useless unless you want to get one with the lights in it.
2004 F350 CC DRW King Ranch
lilpooh is offline
Overhead console supr87gt 2008-2010 Body & Suspension 5 08-23-2009 04:13 PM
Overhead console Matt05 General Ford Truck and Excursion 3 12-29-2008 05:19 AM
Overhead console swap? 5gear General Ford Truck and Excursion 3 07-28-2007 12:27 AM
overhead console mturner719 General Ford Truck and Excursion 0 05-28-2006 02:54 AM
Excursion Overhead Console Puddle Pirate General Ford Truck and Excursion 0 08-10-2005 08:35 PM
