DIY Breaker Box - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by whanner, this thread has received 7 replies and been viewed 1122 times.
post #1 of 8 (permalink) Old 10-04-2009, 07:47 PM Thread Starter
whanner's Avatar
DIY Breaker Box
I found these 20 amp breaker/switches for $2.50 a peace at a electronics wholesale shop and put them in a $7 electrical box from home depot. I like breakers better than fuses and I can turn them off if I need to. If you do add something like this always put your breaker/fuse as close to the battery for the most protection.... that way if you have a wire chaff it will trip the breaker/fuse and not melt things down.
06' F350
I'm not a Diesel Mechanic or Expert. All posts are just guesstimations.
4" Turbo Back Exhaust, 2" lift in front,1" Lift In the Rear, EGT Gauge, ARP Studs.
whanner is offline
post #2 of 8 (permalink) Old 10-04-2009, 09:02 PM
bushpilot's Avatar
only issue i see is that NONE of that is water proof !
Don R.
Truck Audio,
bushpilot is offline
post #3 of 8 (permalink) Old 10-04-2009, 09:38 PM Thread Starter
whanner's Avatar
Ill try to keep the truck out of the lake.
06' F350
whanner is offline
post #4 of 8 (permalink) Old 10-04-2009, 10:15 PM
Saftman's Avatar
What are you running off of them?
Saftman is offline
post #5 of 8 (permalink) Old 10-04-2009, 10:28 PM Thread Starter
whanner's Avatar
2 inverters inside the truck, one in front one in back and a set of 12v outlets for the front and back for phone chargers etc. when we travel the kids always have something running/charging.
06' F350
whanner is offline
post #6 of 8 (permalink) Old 10-05-2009, 01:59 AM
Pics of your inverter setup?
2004 6.0L F350 Lariat Auto 4x4 CC/LB/DRW - sold
Sumimoto 255/70/22.5 on American Force Classic 22.5 wheels, 4.88 w/Truetrac rear, Mag-Hytec front/rear covers, Mag-Hytec 5R110W trans pan and '08 improved filter, custom front/rear springs from National Spring, Bilstein shocks, Bilstein dual stabilizer shocks, 4" stainless turbo back to a FTE single 6" stack, ARB Snorkel intake, Dfuser coolant filter kit, CFM++ Large Mouth, Doug's custom intake manifold, Powermax turbo w/batmowheel, Warren 175/75 injectors, ARP studded, custom CCV reroute, fan shroud removed, Diehard Platinum PM-1 batteries relocated, permanently installed battery tender with front/rear plug in access, HD250 amp alternator w/remote rectifiers, (9) ISSPRO Performax gauges, Nathan K5s, Warn hidden winch bumper kit, Warn 16.5k winch, Reflexxion steel hood, Jimmijammers, Britebox, Retro Solutions, ATTA 50gal Bed tank/tool box combo, Titan 67gal main tank..Hellman sumped, custom regulated return w/Fuelab pump, 6.4 oil filter canister, AMP steps, F650 lower dash w/nine switch panel , Carling switches, SCT X2 and stuff
boobin is offline
post #7 of 8 (permalink) Old 10-05-2009, 02:04 AM Thread Starter
whanner's Avatar
too ashamed to show that....its just settin be hind the seat.
06' F350
whanner is offline
post #8 of 8 (permalink) Old 10-05-2009, 02:31 AM
bushpilot's Avatar
its a great idea and concept, i like it but its not safe.
seriously the engine bay isnt even remotely moisture proof, and
the wires feeding into the box in the photo are completely open, they
need to be sealed & the switches (since they arent water proof) would
benefit immensely from a weather tight cover.
an improvement could be to FUSE close to the battery and then move the
breaker box inside the truck where its a little bit more dry
there are plenty of waterproof high amp (50-150+) circuit breakers available...theyre
commonly used in car audio and marine applications.
http://www.stingerelectronics.com/se...cuit%20breaker
Don R.
Truck Audio,
