05 6.0 Whistling Noise @ High Boost - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Snox49x, this thread has received 6 replies and been viewed 5565 times.
post #1 of 7 (permalink) Old 11-07-2009, 05:27 PM Thread Starter
Last winter I had my turbo cleaned (it was starting to stick). Since then when you get over 25 lbs of boost you get a "tea kettle" like whistle from under the hood. This really only happens when its cold outside (below 40-45). Seems to have no effect on performance just wondering what it may be. Truck is an 05 w/ MBRP turbo back exhaust and SCT. Will do it stock or with any of the tunes from ID. It also does NOT puke. Any ideas??
Snox49x is offline
post #2 of 7 (permalink) Old 11-07-2009, 05:40 PM
********* and Mafia #90
Bcarriveau's Avatar
Check all boost boots very well for cracks..
It could be your degas bottle cap as well..
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 7 (permalink) Old 11-07-2009, 07:40 PM
9/11/01 343
03RescueDiesel's Avatar
Send a message via AIM to 03RescueDiesel
Ya do you have the updated cab for the degas bottle ? also check your boost tube going from the turbo to the intercooler.
03 F250 PSD CC LB Fx4 Wouldnt you like to know whats going
TDG Singles club #228
TDG RIDIN' DIRTY #43
TDG Member Feb 2006
Qauntico Fire Dept, Dale City Volunteer Fire Dept
9/11/01 All Gave Some Some Gave All 343.
03RescueDiesel is offline
post #4 of 7 (permalink) Old 11-08-2009, 02:10 AM
...It may not puke now, but I have to tell ya, that is exactly the same sound my engine started making about a year ago. Shortly thereafter, my engine started puking...little by little until the last 4 months or so before I tore mine down 2 months ago, I had to add a gallon of coolant roughly every 2 -3 weeks! I milked it as long as I could until I finally bit the bullet and did the head studs and new head gaskets after the HPOP STC fitting and FICM failed simultaneously!
2006 F350 King Ranch, CC Dually, 6.0L, auto/torqshift,4X4, all options except moon roof. 4:30's replaced with 3:73's (yes, thats correct), Gear Vendors auxilary overdrive unit, ID's SCT2 Xtreme Race with full TC lockup, MSD Digital propane injection with 23.9gal propane tank, DPPI 304 stainless dual exhaust & AFE Proguard filter & custom intake elbow. :Thumbup:
bigblue777 is offline
post #5 of 7 (permalink) Old 11-08-2009, 07:59 PM
harleystroker's Avatar
Send a message via Yahoo to harleystroker
do you have the plastic cold side intercooler piping?
04 Harley F250 c/c s/b: 06 headlights, 3'' rough county lift, Eagle 20's, 35'' tarragrapplers, 4'' turbo back magnaflow with cat/muffler delete, 6000k HID's, Recon line of fire/ mirror lights/3rd brake/&Tales,Studs/gaskets,Tuned SCT X3,STL strobe kit, Icon shocks,Dfuser Egr/ Egr cooler delete, 03 turbo
http://i135.photobucket.com/albums/q...04/sq_com4.gif
harleystroker is offline
post #6 of 7 (permalink) Old 11-09-2009, 04:08 AM
same problem on a 05
I have been to the dealer 4 times on this. They can not find the problem. It sounds like a bad bearing.
Its going back to the dealer to Monday for the same problem again. If they Fix it this time I will post back.
They have replaced the items below
Boots.
Pipe to the intercooler from the turbo
Twice the seal comming of the turbo
krdono2 is offline
post #7 of 7 (permalink) Old 11-09-2009, 01:39 PM
bluovldeezl's Avatar
Check for leak in y-pipe bellows. Mine makes a noise like a bearing is out and I have a leaky y-pipe. Took forever to find the problem till one day I had the hood up and flogged on the throttle a couple times and thats when I seen the smoke coming up from drivers side. Might not be the problem, but it's worth checking.
2006 F-250 ccsb 4x4
NOT STOCK!!
bluovldeezl is offline
High Pitch Whistle Noise prolxstang89 1994-2003 7.3L Power Stroke 9 01-27-2009 03:22 AM
Whistling Turbo snerdle 2003-2007 6.0L Power Stroke 2 09-26-2007 05:13 AM
Funny high pitched noise txdieselpower 2003-2007 6.0L Power Stroke 6 09-01-2007 07:11 PM
Low RPM High Gear tranny noise FX4DUDE 2003-2007 6.0L Power Stroke 4 06-25-2007 08:49 PM
Squeeking Noise At High Rpm F250SMOKER 2003-2007 6.0L Power Stroke 8 04-25-2006 04:49 PM
