Homemade coolant filter system - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jdydiesel, this thread has received 58 replies and been viewed 17832 times.
post #1 of 59 (permalink) Old 01-08-2010, 08:34 PM Thread Starter
Dually Club #3
jdydiesel's Avatar
So I decided to make my own coolant filtration system for my 06. I bought the coolant filter base and filter from Napa. I have bought most of the brass stuff: valves, hose fittings. What my questions are is on the pipe fittings that I need to use. I can buy brass fittings but that would be very expensive. So I have found galvanized fittings but I am concerned about the dissimalar metal and getting galvanic corrosion. Has anyone seen this or have any experience with putting one of these systems together? Should I use brass, galvanized, or find black iron fittings? The next question I have is I have heard that we should use distilled water in the 6.0l, but will soft water work? I have a well that is neutalized then softened. Will soft water work the same as distilled water in our trucks? When I am done I will post pictures of the install.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #2 of 59 (permalink) Old 01-08-2010, 10:11 PM
Trip's Avatar
Stick with distilled... Softened water has a high dissolved particle # higher than normal well water. And well water will be higher than your local city water, stick with a couple of gallons of distilled, your goal in the filtration system is to keep stuff out of your cooling system.
WALNUT (anti-ACORN) member#23
Trip is offline
The Following User Says Thank You to Trip For this addition to TDG:
jdydiesel (01-08-2010)
post #3 of 59 (permalink) Old 01-08-2010, 10:15 PM Thread Starter
Dually Club #3
jdydiesel's Avatar
Ok on the distilled water, I want this to work the best it can.
Jason
post #4 of 59 (permalink) Old 01-08-2010, 10:18 PM
Trip's Avatar
what parts are you wanting to go galvinized on? If it is just the T's go to O'reilys or Napa grab the plastic generic ones... that is what came with my kit... (since when dose ford approve parts made in china)?
Trip is offline
post #5 of 59 (permalink) Old 01-08-2010, 10:25 PM Thread Starter
Dually Club #3
jdydiesel's Avatar
i was going to use galvanized for the elbows and close nipples. These are what I am using to attach the valves to the filter base.
Jason
post #6 of 59 (permalink) Old 01-08-2010, 10:45 PM
Trip's Avatar
I am unfamiliar with the effects that galvanized will have on our cooling system... so I will leave that for someone more knowlageble than myself...
Trip is offline
post #7 of 59 (permalink) Old 01-08-2010, 10:56 PM Thread Starter
Dually Club #3
jdydiesel's Avatar
Thanks, I know what it does in straight water systems, just not with this coolant.
Jason
post #8 of 59 (permalink) Old 01-08-2010, 11:29 PM
69cj's Avatar
I like being on the safe side. These engines aren't cheap. I would go with brass, stainless or machined aluminum. That is why I think the kit from dieselsite is worth the money. How much is your time worth?? I consider mine to be valuable and the older you get the more it is worth.
69cj is offline
post #9 of 59 (permalink) Old 01-09-2010, 04:52 AM
rocky1074's Avatar
The coolant kit from Dieselsite is WELL worth the money and a easy install!!
2003 F-350 SD 6.0 Crew Cab DRW
Dieselsite Coolant Filter; High Idle mod.
24" Windshield Wipers; Prodigy Brake Controller;
Fumoto Valve; ZooDad Mod; Magnefine Power Steering Filter; Edge Insight
07 Harley Ultra Classic Electra Glide
rocky1074 is offline
post #10 of 59 (permalink) Old 01-09-2010, 12:48 PM
9/11/01 343
03RescueDiesel's Avatar
Send a message via AIM to 03RescueDiesel
Well if you cant afford 110 bucks for the complete kit, expensive fittings shouldnt be a big deal since your trying to save money.
03 F250 PSD CC LB Fx4 Wouldnt you like to know whats going
TDG Singles club #228
TDG RIDIN' DIRTY #43
TDG Member Feb 2006
Qauntico Fire Dept, Dale City Volunteer Fire Dept
9/11/01 All Gave Some Some Gave All 343.
03RescueDiesel is offline
Coolant Filter System for Christmas BillsFan 1994-2003 7.3L Power Stroke 3 12-03-2009 03:46 AM
Anyone made their own coolant filter system? jeffro22 2003-2007 6.0L Power Stroke 18 02-24-2009 10:15 PM
coolant filter system rum4 Supporting Vendors Forum 6 01-31-2008 09:27 PM
homemade fuel system for SD strokedout_07 1994-2003 7.3L Power Stroke 3 12-10-2007 01:24 PM
Bypass coolant filter system POWER STROKE 99 Supporting Vendors Forum 3 02-20-2007 12:16 AM
