engine ????? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by michael8840, this thread has received 6 replies and been viewed 1417 times.
post #1 of 7 (permalink) Old 05-16-2010, 10:37 PM Thread Starter
michael8840's Avatar
Unhappy engine ?????
Hi troops,
I am wondering why my 2003 F-250 sounds different then a 2005 model and also why the truck drives like crap untill it is a bit warmed up
It is a sign that something is coming up??
thanx guys,
michael
1996 7.3L powerstroke econoline E-350 cargo van
1999 7.3L superduty F-350 crew cab,lb
2003 6.0L powerstroke F-250 crew cab,sb FX4
2006 6.0L powerstroke F-250 crew cab,lb
1992 chevrolet caprice classic (305 cid
1998 mercury grand marquis LS
michael8840 is offline
post #2 of 7 (permalink) Old 05-17-2010, 12:08 AM
Got Torque?
ralphinnj's Avatar
Images: 80
Based on your signature, I assume you own the 2003, and you are comparing it to someone else's 2005. There are a lot of things that will make them sound different. Would help if you told us the mods to both trucks. For starters, your 2003 has a 10-vane turbo, whereas the 2005 has more vanes (not sure if it is the 13 or 15-vane variety). More vanes means LESS "F-16" type sound. There are many who have swapped their 05' and later 6.0 turbos to get an 03' version with less vanes. Just for the sound!
Anyway, the turbos make a big difference in sound. Now, another factor is the exhaust. If you 03' has no aftermarket exhaust and the 05' does (or vice versa) there will be a huge difference in how they sound.
Please tell us the mods/set up and we will be able to tell you what you are hearing.
Regarding it taking time for your 03' to behave normally, that probably means your turbo is sticking. Could be other things, like a fouled up EGR valve, etc. If you are handly, rebuild and clean the turbo and see if that fixes it. I'd also clean the EGR valve. If you're not handy, bring it to a diesel tech to get that work done. I assume it is no longer under warranty.
Ralph
Black 2003 F350 Dually, Nothing Stock
Other Rides:
Black 2006 300C SRT8
Black 2012 CTS-V (630HP)
Black 2008 Mercedes E550
ralphinnj is offline
The Following User Says Thank You to ralphinnj For this addition to TDG:
michael8840 (05-17-2010)
post #3 of 7 (permalink) Old 05-17-2010, 01:27 AM Thread Starter
Thank you very much,
Both the trucks are bone stock,what is bothering me is that the 2005 engine sounds much quieter than my 2003
It could be that the turbo is sticking because I always get a p132b code,I just delete it and go one
michael
post #4 of 7 (permalink) Old 05-18-2010, 02:26 AM
SmokeCloud's Avatar
I believe in either 05 or 06, they started Commonizing the head's basically using 6.4L heads on a earlier model for testing purpose's. there's a way to check for that but i forget.
Also as mentioned before, the 05 had more veins in the turbo, they had 15 as opposed to the 10 in the 03.
Real Trucks Burn Diesel!
SmokeCloud is offline
The Following User Says Thank You to SmokeCloud For this addition to TDG:
michael8840 (05-18-2010)
post #5 of 7 (permalink) Old 05-18-2010, 02:35 AM
Commonization changeover date is 1-16-08.
ricatic is offline
The Following User Says Thank You to ricatic For this addition to TDG:
post #6 of 7 (permalink) Old 05-18-2010, 02:45 AM
SmokeCloud's Avatar
That doesn't make sense, 6.0's had 6.4L heads on them, if they were made in 08, they wouldn't be making 07 models.
post #7 of 7 (permalink) Old 05-18-2010, 02:54 AM
& amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; quot ;Mis s me yet&a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;q uot; George Bush
WasGas's Avatar
Oil type and age seems to play a big part on how loud the engines are.
AND YOU THOUGHT CARTER SUCKED
WasGas is offline
The Following User Says Thank You to WasGas For this addition to TDG:
#08-06-04-054: Snow Intrusion into Air Cleaner, Check Engine Light On, Engine Reduced ripmf666 GM TSB Info 0 08-10-2009 04:46 AM
Can you look at a 6.6 engine and tell whether its a LB7 or a LLY? PapaEd General GM Truck Forum 6 04-22-2008 05:51 AM
Possible to measure engine deck specs on engine in truck? Trulyvintage 7.3L and 6.9 IDI (Pre 1994) 3 06-16-2007 04:10 AM
PSD Engine Oil thompsd 2003-2007 6.0L Power Stroke 47 05-04-2007 03:00 PM
CAT engine #'s dondiesel444 Medium and Heavy Duty 6 11-10-2005 08:15 PM
