high idle on my standard - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsracer2010, this thread has received 17 replies and been viewed 2074 times.
post #1 of 18 (permalink) Old 07-01-2010, 08:18 PM Thread Starter
so on the hs performance page theres a link and pics of how to wire a ground under the dash for the high idle on my starndard cummins and im not having luck finding this wire. has anyone done this and can help me in finding it and veryifying it? i think i got the wire but not sure because the pic doesnt show where the wire comes from?
http://www.hsperformance.com/?p=4556
cumminsracer2010 is offline
post #2 of 18 (permalink) Old 07-01-2010, 08:34 PM
ADMIN/MAFIA
neeltburn's Avatar
PM Mastercaster he has done it as well as Sootbandit. Sorry I'm not more help but it is in the wire bundle over top of the clutch to the left of the steering Colum.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
cumminsracer2010 (07-01-2010)
post #3 of 18 (permalink) Old 07-01-2010, 09:21 PM Thread Starter
so, does it come from the fire wall or the block of wires ?
post #4 of 18 (permalink) Old 07-01-2010, 09:41 PM
ADMIN/MAFIA
neeltburn's Avatar
I think it comes from the wire block, not 100% sure it is a green wire with white trace I believe.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 18 (permalink) Old 07-02-2010, 12:01 AM Thread Starter
yea, thats my delema i dont want to mess with the wrong wires , the website sais green, nothing about white, but i agree with you. i seen a couple there like green and white my self, plus i called h&s and the guy couldnt tell me anything more than they got the pic from somewhere else and to look at it, ( as if i hadnt allready ) anyone has done this or can help, let me know plz?
post #6 of 18 (permalink) Old 07-02-2010, 12:53 AM
ADMIN/MAFIA
neeltburn's Avatar
I just send Sootbandit a Text to check out this thread.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 18 (permalink) Old 07-02-2010, 12:57 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
The wire is a loose wire it will have a end butt black i believe that you will cut off and either wrap around the bolt head in the pic or put an end on like they did. I just wrapped mine around it. Like i said the wire is free kinda by itself and its not very long but if you got a wire that is loose and green like that then you are in business. Hope this helps
Military Quote Of The Year
SOOTBANDIT is offline
post #8 of 18 (permalink) Old 07-02-2010, 05:45 PM Thread Starter
its helps thanks, i still cant find a loose wire tho, all mine are wrapped up tight , and no for sure on strictly green or green with white stripe? and the guy at hs sais i have to have the programmer to get the high idle on my truck, this true?
post #9 of 18 (permalink) Old 07-02-2010, 06:14 PM
ADMIN/MAFIA
neeltburn's Avatar
Dodge can turn it on with the starscan tool, but you will need that wired grounded first. HS or smarty programers have the high idle enabled in their software.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #10 of 18 (permalink) Old 07-02-2010, 09:03 PM Thread Starter
think if i took it do the dealer that it could b done? they could find the wire?
Skweeker Mod (High Idle or Aux. Idle) CBSuperduty Ford - Modification instructions, Product installs and Tech Articles 23 12-31-2009 03:22 AM
High Idle & High Idle Kicker... Mopar1973Man 5.9L Cummins (1998.5-2002) 4 12-25-2008 01:36 PM
High Idle & 3 Cylinder Idle Mopar1973Man 5.9L Cummins (1998.5-2002) 11 11-02-2007 01:44 AM
High Idle W-900 STUDIO 5.9L Cummins (1998.5-2002) 9 02-01-2007 07:02 PM
6.0 high idle? bobo 2003-2007 6.0L Power Stroke 23 12-01-2005 12:11 AM
