Smog Check - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dodgefarmer, this thread has received 3 replies and been viewed 1027 times.
post #1 of 4 (permalink) Old 07-18-2010, 03:51 AM Thread Starter
Dodgefarmer's Avatar
Smog Check
FYI, those of you who are in states with smog checks on diesels.
Note: I am stock, so had no worry of passing but thought I would let others know of the smog check process.
Had mine done the other day at a repair/tire shop where I get most of my repairs and tires done so they know me well. The smog tech person did get under the truck to check the exhaust system, looked under the hood with flashlight to see that it was stock and every thing hooked up. Then hooks up computer to under dash diagnostics port to check for codes etc. Then he his required to accelerate motor twice while looking at exhaust with a Calif. spec white painted board behind tail pipe looking for smoke.
When all passes he prints out a certificate and I pay $47.50 so CA will issue a new registration.
singles club # 198
Dodgefarmer is offline
post #2 of 4 (permalink) Old 07-18-2010, 01:17 PM
ADMIN/MAFIA
neeltburn's Avatar
Glad it went well for you! How's the J35 doing now Mike.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 4 (permalink) Old 07-18-2010, 05:48 PM Thread Starter
No problems, fuel mileage seems the same maybe couple tenths better. Still see the radiator fan engaging more often like I posted before, of course its been 102-105 degrees lately. Cold are really good at the end of the day.
singles club # 198
post #4 of 4 (permalink) Old 07-18-2010, 06:07 PM
ADMIN/MAFIA
neeltburn's Avatar
Good deal. It's been hot here too.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
Ca smog is almost here jdydiesel The Parking Lot 25 07-23-2010 03:52 AM
SCT and Smog? legend14 2003-2007 6.0 Tuner Forum 27 06-15-2010 03:12 AM
CA SMOG broth 2008-2010 6.4L Power Stroke 29 05-17-2010 03:59 PM
smog check spock Southwest 0 01-15-2010 03:50 PM
SCT and Smog Mustang42 2003-2007 6.0L Power Stroke 11 12-16-2005 09:13 PM
