XRT Tune/Mileage/Tire Size Cal. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SOOTBANDIT, this thread has received 2 replies and been viewed 1072 times.
post #1 of 3 (permalink) Old 07-25-2010, 06:48 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
For XRT users wat turbo tuning do you use and wat tune do you use for best fuel economy? Also anyone wit aftermarket tires did you set your XRT to the specified tire size??? I am trying to figure out this speedo thing cause i believe it is off i have a GPS and if i set my XRT to the correct tire size im off bout 3-4mph from my speedo. Now if i set it below my tire size im right on wit my GPS so wat gives???? Do i trust the GPS always or do i actually go by slower speedo??? I also have saw my best mileage on the "hwy" is the hot damn 175 wit NO TURBO TUNING and i got a best of 22.3 hand calc on 497mi before a pit stop.
Military Quote Of The Year
SOOTBANDIT is offline
post #2 of 3 (permalink) Old 07-28-2010, 05:47 AM
6.7L Man Van
-lenny-'s Avatar
I had aggressive turbo tuning downloaded to keep egts down towing my trailer, and running Hot damn 175 empty I got my best mpg. I set my speed by gps, ended up being almost 2 inches less than actual tire size. No biggie though. FWIW, when I got my MiniMaxx I set it to the same small tire size and the speedo was right on!
08 MC 3500 68RFE
Mostly Stock
-lenny- is offline
post #3 of 3 (permalink) Old 07-28-2010, 06:30 AM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Sweet i run the non turbo tune hot damn 175 and it is the best so far on mpg only 3psi and roughly 650-700 egts on flat!
tire size ckbobcatservice Duramax 2006-2007(LBZ & LLY) 2 04-28-2007 02:01 PM
tire size? Kleiner General Ford Truck and Excursion 5 04-04-2007 09:18 AM
SCT and Tire Size LokiWolf 2003-2007 6.0 Tuner Forum 7 07-26-2006 11:33 PM
tire size? diesel_ram_man 5.9L Cummins (2003-2007.5) 0 07-21-2006 10:52 PM
Tire Size stillcummin 5.9L Cummins (2003-2007.5) 1 07-09-2006 07:43 PM
