07-6.7L Blackstone report with custom AMSOil bypass - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 2007CumminZ, this thread has received 5 replies and been viewed 1591 times.
post #1 of 6 (permalink) Old 07-31-2010, 12:07 AM Thread Starter
I am running factory oil filter & AMSOil bypass filters being fed out of top of factory filter port.:-laf
With 4,000 miles on the oil I changed the factory filter & small bypass mount filter (not the bypass filter) and added container of STP oil treatment and topped of with new oil. (Maybe) 1 1/2 quart of new oil. I then ran engine to have 7,500 miles on the oil. Blackstone report below.
They are suggesting run oil another 10,000 miles before next report.
Click here for custom AMSOil bypass install.
Click here for enlarged file viewing.
2007CumminZ is offline
post #2 of 6 (permalink) Old 08-01-2010, 03:45 AM
ADMIN/MAFIA
neeltburn's Avatar
So they are saying that this change interval will be 17500 mile? That's amazing. Im curios as to what air filter you are running and why the silicone levels spike and are down now, did you change anything?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 6 (permalink) Old 08-01-2010, 05:32 AM Thread Starter
Yes they are saying 17,500 miles but I will change 2 of my filters at 5k from now like I did before. I am running K&N high flow in stock air box. I do not now why the silicon has changed.
post #4 of 6 (permalink) Old 08-01-2010, 01:10 PM
ADMIN/MAFIA
neeltburn's Avatar
Have you cleaned the air filter in that time frame?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 6 (permalink) Old 08-01-2010, 01:24 PM Thread Starter
Yes, I check it one a month. Most of this 7,500 miles was towing heavy.
post #6 of 6 (permalink) Old 10-23-2010, 10:53 AM Thread Starter
Just received a new bypass filter from my AMSoil dealer. After our next camping trip I plan to do a complete service and change all three oil filters and swap over to complete AMSoil in everything. I have x-large front and rear diffs with drain plugs so it will be easly to make the swap. The truck now has 48k mileage on it and would be a good time to swap. I have run the present oil now for 12 months.
Amsoil Bypass kit PhilipR General Dodge Discussion 3 08-04-2010 02:49 AM
Amsoil Dual Bypass JimTJr 1994-2003 7.3L Power Stroke 7 05-12-2010 03:37 PM
Custom AMSOil bypass Blackstone results 2007CumminZ 6.7L Cummins (2007.5-2011) 0 06-17-2009 12:16 AM
Anyone running AMsoil Bypass kit- need help jeffro22 2003-2007 6.0L Power Stroke 15 05-08-2009 06:44 AM
Amsoil Bypass setup hhrecovery General Diesel 2 12-20-2006 01:59 PM
