6.7L Cummins Larger Capacity Radiator - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bobcat698, this thread has received 0 replies and been viewed 1095 times.
post #1 of 1 (permalink) Old 08-01-2010, 09:48 PM Thread Starter
Would there be any interest in a larger capacity radiator for the 6.7L?
I dropped mine off at my local radiator shop to see if we can find a suitable larger core that would drop in without much issue..
Would anyone else be interested, depending on price?
Got some good leads so far, there seems to be plenty of room to go with a thicker actual "Core" and still be a little narrower than the actual tank width.
Take a closer look at a stock radiator and you should understand what I mean.. they aren't even taking advantage of the width they have.. it necks down almost 1/2 inch on either side from the tanks to the core!
I will keep everyone posted, I might be able to make this a production part in the end!
Bobcat698 is offline
Idle with larger injectors? crazyrc 2003-2007 6.0L Power Stroke 7 06-22-2009 01:16 PM
Larger injectors and CPs heavyhaller 2003-2007 6.0 Tuner Forum 4 06-21-2009 04:08 AM
Larger Turbo vs. EGT's? willy91 12 Valve Performance 23 04-06-2008 01:25 PM
Larger Fuel Tank cattech05 2008-2010 6.4L Power Stroke 7 03-15-2008 02:29 AM
Which would be better Twins or Larger Single on a 6.0L JTByeNow 2003-2007 6.0L Power Stroke 20 04-05-2006 11:29 PM
