Exhaust Brake ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dodgefarmer, this thread has received 4 replies and been viewed 1540 times.
post #1 of 5 (permalink) Old 08-17-2010, 04:13 AM Thread Starter
Dodgefarmer's Avatar
Exhaust Brake ?
Just got back from camping on the coast. Going there towing my 5er weighing 12,000+ lbs my EB started surging one time. It was on a 8% down hill grade and was in 3rd gear. It was a rapid surge of on and off of 1 second or less. I momentarly got one the throttle to disengage the EB then all was fine. Never did it again. This trip has grades of up to 10% and did not act up any more.
Question: Is this how the Variable vanes in the turbo start acting if they are sticking? I am completly stock, 85,000+ miles and all flash updates done. Turbo never has been cleaned for sticking like many of you have had done. Hopeing it was a one time thing since it hasn't done it anymore.
singles club # 198
Dodgefarmer is offline
post #2 of 5 (permalink) Old 08-17-2010, 01:05 PM
ADMIN/MAFIA
neeltburn's Avatar
It could have just been a small peice of soot stuck in it. I wouldn't worry to much if it worked the rest of the trip. Do you run it all the time?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 5 (permalink) Old 08-17-2010, 11:30 PM Thread Starter
I run it about 50% of the time when not towing.
singles club # 198
post #4 of 5 (permalink) Old 08-18-2010, 01:34 AM
ADMIN/MAFIA
neeltburn's Avatar
mike run it all the time for the next tank of fuel and then get a load on it. If it is still not acting up I'm betting it was a fluke.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 5 (permalink) Old 08-23-2010, 03:29 AM
stillcrazyinlaw's Avatar
Images: 3
I run mine all the time, and have had that same situation a few times. A little surging then fine, I always figured it was just gunking up a little then cleared up to run fine. I wouldn't worry to much, mine has also never been cleaned at 50,000 miles.
stillcrazyinlaw is offline
Exhaust Brake ?'s glowplugsr4grls 5.9L Cummins 12 Valve (1994-1998.5) 9 07-14-2009 01:14 PM
VGT exhaust brake jdydiesel 2003-2007 6.0L Power Stroke 30 07-14-2009 03:53 AM
exhaust brake heathww 5.9L Cummins (1998.5-2002) 5 03-14-2009 12:04 AM
Exhaust Brake King0581 1994-2003 7.3L Power Stroke 3 03-30-2008 03:24 AM
Exhaust Brake? Duke 2008-2010 6.4L Power Stroke 3 11-14-2006 09:45 PM
