new to 6.7 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by King, this thread has received 12 replies and been viewed 2337 times.
post #1 of 13 (permalink) Old 08-20-2010, 05:02 AM Thread Starter
new to 6.7
What does a guy have to know about these trucks Im picking one up today?
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
post #2 of 13 (permalink) Old 08-21-2010, 01:25 AM
Dodgefarmer's Avatar
Drive hard and make it work, the 6.7 and the dpf don't like easy driving, another words have a heavy foot on the go pedal. Must keep the exhaust hot to keep the dpf clean. That doesn't mean you can't do city driving, stop-n-go, but don't do it all the time. I am at 85,000 miles on my 07 and no problems except a water pump leak.
Oh yea, most people will recomend to leave the EB on even when not towing. Good Luck
singles club # 198
Dodgefarmer is offline
post #3 of 13 (permalink) Old 08-21-2010, 04:14 AM
ADMIN/MAFIA
neeltburn's Avatar
... Now that is truly the best advice.. I agree on running the EB all the time.. Now if you don't want to stay stock I can offer other advice but, the 6.7 in stock form needs to be worked. Let us know how you plan to use your truck, are you wanting to keep it stock, do you want to mod it? There is a wide list of things you can do with these trucks, but that will depend on what you want to get from it and how you plan to use it.
I will also add when I was stock, My problems slowed down when I switched from Rotella T 15 W 40 to Valvoline Premium Blue 15 W 40, and stopped using fuel additive. (just my experience)
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 13 (permalink) Old 08-21-2010, 02:11 PM Thread Starter
thanks,
I will probly put a programer of some kind in it I had a edge in my old truck and really liked it. But first it needs 6 tires a pinoin seal and well i haveent looked it over all that looked it over 100%. My preform service message is on whats the procedure for cleaning the egr valve and cooler? And how do you reset the message?
King is offline
post #5 of 13 (permalink) Old 08-21-2010, 03:02 PM
ADMIN/MAFIA
neeltburn's Avatar
thanks,
The Preform Service message is for the DPF... Does the truck have a CEL on? I am not aware of a way to reset it other than with a dealer starscan tool.
Just a note but, programmer or chip on a DPF equipped truck can cause a very least more regens and could cause damage to the DPF.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 13 (permalink) Old 08-22-2010, 03:45 AM Thread Starter
No cel. so do they take and repkace the dpf the or what? How do you get around it I seen some flash type modules that plug in under the dash. I have noticed the milage is very poor.
King is offline
post #7 of 13 (permalink) Old 08-22-2010, 04:22 AM
ADMIN/MAFIA
neeltburn's Avatar
They can do what is called a forced regen and burn it off.l you have several options. You can take to it the dealer and have it fixed.. which I would do first. then you could delete it like most do.. Get rid of the DPF and the EGR. The EGR is what really does the harm. It just depends on what you want to do. My mileage was horrible until I tuned it and got rid of stuff, not I pull about 18MPG city
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #8 of 13 (permalink) Old 08-23-2010, 03:59 AM Thread Starter
My milage is very poor, I have not figured it out exactly but 11.5-12 empty. What would I need to get rid of all that junk? Does someone sell a kit? Ive got a 1500 mod budget.
King is offline
post #9 of 13 (permalink) Old 08-23-2010, 02:15 PM
ADMIN/MAFIA
neeltburn's Avatar
You would need a tuner from either smarty or h&s a tbe is the best but a simple delete pipe will work. Then a egr blocker plate and your good to go. A set of gauges is also a good idea.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #10 of 13 (permalink) Old 08-23-2010, 08:31 PM
thanks,
This worked for me as far as message reset....
1. Turn the ignition switch to the ON position (Do not start engine).
2. Press and release the brake pedal two times.
3. Fully depress the accelerator pedal slowly two times within 10 seconds.
4. Turn the ignition switch to the OFF/LOCK position.
''Then click your heals three times while repeating "There's no place like home. There's no place like home. There's no place like home''.
2008 Dually Quad Cab, 6 Speed Auto 3.73, Edge W/Attitude,21/2" Hell bent Leveling Kit, Firestone Airbags, DIY Step Bars,EGR Delete, 4" Turbo Back Exhaust From K-2 Diesel, Cummins Mud Flaps,ATC Topper and Rhino lined rockers front to back
Rev. is offline
The Following User Says Thank You to Rev. For this addition to TDG:
King (08-24-2010)
