Know you guys can help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by goatman1419, this thread has received 5 replies and been viewed 1058 times.
post #1 of 6 (permalink) Old 09-14-2010, 11:28 AM Thread Starter
Have 08 w/ 49668 deleted DPF and EGR have two beeps and overhead shows service required see dealer now. SSSooo brought it in and they have no idea or how to reset the damn beeping. XRT shows no codes and truck is running fine no lost power or mileage. So wtf? Is this some regular maintenance crap or is dodge trying to make a buck. Any help or ideas how to reset this overhead beeping?
goatman1419 is offline
post #2 of 6 (permalink) Old 09-14-2010, 11:50 AM
ADMIN/MAFIA
neeltburn's Avatar
Clear codes even though there are none. If that doesnt do fix it reload your tune and you should be good to go.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
goatman1419 (09-14-2010)
post #3 of 6 (permalink) Old 09-14-2010, 01:20 PM Thread Starter
OK I cleared the codes twice with no luck i'll try to redownload the tuner and let you know.
post #4 of 6 (permalink) Old 09-14-2010, 05:17 PM Thread Starter
Redownloaded tuner and so good so far thanks again
post #5 of 6 (permalink) Old 09-15-2010, 12:10 AM
ADMIN/MAFIA
neeltburn's Avatar
No problem, a few guys get this everyone once in a while. Seems like its just the way the system scans for DPF operation.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 6 (permalink) Old 09-15-2010, 02:27 AM
1. Turn the ignition switch to the ON position (Do not start engine).
2. Press and release the brake pedal two times.
3. Fully depress the accelerator pedal slowly two times within 10 seconds.
4. Turn the ignition switch to the OFF/LOCK position.
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
What do you guys think of this 07? 1996MONTESS Duramax 2006-2007(LBZ & LLY) 5 06-12-2007 11:28 PM
Hey Guys Jackie Introductions 6 03-22-2007 12:57 AM
hey guys what do you think bada$$dodge2000 2003-2007 6.0L Power Stroke 11 02-27-2007 02:09 PM
Hi Guys mrsdmaxallitech Introductions 12 02-18-2007 01:48 AM
