Front pinion seal - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rev., this thread has received 2 replies and been viewed 1310 times.
post #1 of 3 (permalink) Old 09-15-2010, 03:49 PM Thread Starter
Front pinion seal
Anybody got an idea how rough it is to remove the yoke and what the torque is on that. 2008 4x4 Dodge dually
2008 Dually Quad Cab, 6 Speed Auto 3.73, Edge W/Attitude,21/2" Hell bent Leveling Kit, Firestone Airbags, DIY Step Bars,EGR Delete, 4" Turbo Back Exhaust From K-2 Diesel, Cummins Mud Flaps,ATC Topper and Rhino lined rockers front to back
Rev. is offline
post #2 of 3 (permalink) Old 09-22-2010, 02:18 AM
I did mine last weekend its not to bad you need a thin walled socket 1 1/4 inch 12 pt 6 wont fit. I tapped the yoke off with a little ball pien hammer.
As for tourqe I always hammer them on with the impact never had an issue doing it that way.
PS if you plan on changing the front diff it will take allmost 3 quarts.
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
post #3 of 3 (permalink) Old 09-25-2010, 01:06 AM Thread Starter
Thanks I got it done took me about 2hrs. Had L5/S1 disc removed about 4 months ago they went in through the front pulled the disc and replaced it with a cage then flipped me over and installed rods pins and screws between L5/S1 for stability 8 more months for full fusion. The work probably should have took about 1/2 hour. I AIN'T GETTING UNDER BLUE AGAIN TILL I HEAL IT WAS A ROUGH 2 HRS.
Rev. is offline
Front Pinion Seal AGGIE00 6.7L Cummins (2007.5-2011) 0 09-16-2009 01:10 AM
Axle/ pinion seal leaks. DEERSNIPER General Ford Truck and Excursion 3 04-26-2007 12:59 AM
Rear Pinion seal leak Extended Power 2003-2007 6.0L Power Stroke 4 06-19-2006 09:42 PM
Flat tow and pinion seal? CSIPSD The Parking Lot 7 04-11-2006 11:56 PM
DANA 80 Pinion SEAL Failures Slaughterhouse General Ford Truck and Excursion 3 04-02-2006 05:53 PM
