P0700 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fjwill, this thread has received 5 replies and been viewed 11266 times.
post #1 of 6 (permalink) Old 12-09-2010, 07:18 PM Thread Starter
P0700
I got this code yesterday tried to clear it and it comes right back .P0700-transmission Control System (mil Request) I do not know what ( mil request) means. any help would be great on under standing this code and what i might can do. Thanks.https://www.thedieselgarage.com/forums/images/smilies/shrugs.gif
fjwill is offline
post #2 of 6 (permalink) Old 12-09-2010, 07:35 PM
ADMIN/MAFIA
neeltburn's Avatar
What all is done to the truck?
Does it have any symptoms? or Just the CEL? MIL requested sounds like it is a limp mode or something, Is it the only code present?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 6 (permalink) Old 12-09-2010, 09:26 PM Thread Starter
I am running a smarty with all deletes. this is the only issue i have had except for the overhead coming on telling me to see dealer now, every now and then. nothing different but have noticed the truck is slow to crank, otherwise she is running strong as ever.
fjwill is offline
post #4 of 6 (permalink) Old 12-09-2010, 09:28 PM Thread Starter
also found out that p0700 is a code form the TCM to tell the ECM to turn on the CEL
fjwill is offline
post #5 of 6 (permalink) Old 12-09-2010, 11:28 PM
ADMIN/MAFIA
neeltburn's Avatar
Ok, Set truck to stock ( as it came from dodge) Clear codes twice..
reinstall the ME file you are running but set the Revo setting for Torque back to stock and see if it stays gone.. Also if you upgrade to 23ME that should take care of your overhead warning.. If the truck is slow to crank, how cold is it where you are? Are Batteries is good shape? How Long has it been since you put a new fuel filter in?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 6 (permalink) Old 02-06-2011, 09:47 PM
I got the same P0700 code last month. I had a hard shift and the Check engine stayed on for about a day and then went away. I figured it was time for the trans filter to be changed, when I took it in they checked for codes on the trans and pulled the pan. It was full of metal. There was a period of time that the oil pressure dropped and $3000.00 later I have a rebuild tranny.
08'3500Mega is offline
Help! P0700 and P0732 Codes hotrodstan GM Transmissions 3 07-06-2010 12:06 PM
DTC P0700, TCM Malfunction Lindy02GMC Duramax 2001-2004 (LB7) 4 05-20-2010 04:05 PM
P0700 Trip 2003-2007 6.0L Power Stroke 1 04-21-2010 06:41 AM
P0700 Code squeeky GM Transmissions 2 01-20-2009 09:20 AM
allison P0700, P0708 code's, need some help sparkchaser221 GM Transmissions 5 02-25-2008 03:24 PM
