2010-2011 CUMMINS WITH MANUAL TRANSMISSION? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jeremiah, this thread has received 3 replies and been viewed 4006 times.
post #1 of 4 (permalink) Old 12-27-2010, 12:24 PM Thread Starter
Banned
Anyone know if the Cummins is detuned with the 6=speed manual tranny? I see that 4.10 rear end is not available with this transmission... Anyone running a manual? Like it?
Jeremiah is offline
post #2 of 4 (permalink) Old 01-03-2011, 10:25 PM
It's 610 lb/ft with the manual.
I have the g56/3.73. I suspect the lack of 4.10's w/G56 has more to do with the final drive ratio. From what I came up with, the g56/3.73 makes about 68rfe/4.10 rpm...?
Default is 3.73. 3.42 is an option. I think most G56 trucks are outfitted with the 3.42 because of the .74 final OD ratio.
G56 Manual w/0.74 final drive ratio in 6th gear, 265/70-17 tires, 654 revs per mile @ 70 mph:
3.42 axle -- 1931 rpm at 70 mph
3.73 axle -- 2106 rpm at 70 mph
4.10 axle -- 2321 rpm at 70 mph (combination NOT available -- just for comparison)
6-Speed Automatic w/0.63 final drive ratio in 6th gear, 265/70-17 tires, 654 revs per mile @ 70 mph:
3.42 axle -- 1644 rpm at 70 mph
3.73 axle -- 1793 rpm at 70 mph
4.10 axle -- 1976 rpm at 70 mph
I actually like the g56 alot. No real reason, just fun to drive.
Hope this helps.
Shonne ## 2006 Dodge 2500 QC *Debadged* Gage Front and Rear -- Frontier Gear Stirrup Step -- Aeroturbine 4040xl -- Aeroturbine DT4050 Tip -- ATS ArcFlow -- AFE Stage 2 -- Lorenz 2.25 Sway Away System
shonne is offline
post #3 of 4 (permalink) Old 01-08-2011, 01:31 AM Thread Starter
Banned
HP Different?
Jeremiah is offline
post #4 of 4 (permalink) Old 01-08-2011, 09:29 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Originally Posted by Jeremiah View Post
HP Different?
Nope just the cost of upgrade to hold more power
Auto 3 to 5 grand
Manual 1500 max
Military Quote Of The Year
SOOTBANDIT is offline
2010 or 2011 Cummins CaptainQ 6.7L Cummins (2007.5-2011) 7 01-17-2011 11:36 PM
2010-2011 Hunting Season neeltburn The Parking Lot 8 11-29-2010 02:47 AM
Going from 2010 to 2011? Anyone? Frans96ss 2011+ 6.7L Power Stroke Diesel 24 10-28-2010 10:06 PM
Motor Trend 2011 Superduty VS 2010 RAM mustang mike 93 2011+ 6.7L Power Stroke Diesel 35 04-15-2010 09:55 PM
2011 Suspension the same as 2008-2010? rmkhauler 2008-2010 Body & Suspension 4 03-19-2010 03:25 PM
