quick question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by buffalobob, this thread has received 10 replies and been viewed 1569 times.
post #1 of 11 (permalink) Old 02-12-2011, 10:27 PM Thread Starter
buffalobob's Avatar
quick question
just a quick question. planning an aux fuel tank in bed. will use the kit to connect directly to the filler hose. will this drive my computer crazy. like going 500 miles with what amounts to no fuel leaving the main tank. i dont care if the overhead is accurate about "miles to empty" but i dont want to screw up the rest of the computer functions. has anybody had a problem
2011 silverado lt, crewcab, short bed, 4X4, d-max/ allison
buffalobob is offline
post #2 of 11 (permalink) Old 02-12-2011, 10:39 PM
ADMIN/MAFIA
neeltburn's Avatar
My overhead isnt acurite any way so i dont see where it would cause a problem. You mean it will have a vavle to fill the oem tank correct?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 11 (permalink) Old 02-12-2011, 10:48 PM Thread Starter
buffalobob's Avatar
there is an install kit with a ball valve in it. connect the line from your aux tank to the filler tube on your truck. the ball valve shuts off flow when the filler tube is full preventing more fuel to drain into your regular tank until level drops. it keeps your stock fuel tank full until auxillary tank is empty. so depending on how large your aux tank, you could drive 700 miles or more before the fuel gauge shows any fuel being used. just wondering if this will effect the ecm which i assume controls this miles to empty function.
post #4 of 11 (permalink) Old 02-13-2011, 12:24 AM
Capacity and cost of the tank? I am looking for around 40-50 gallon. I found a cheap 100 gallon, but that is way to much.
03 3500HD 6x6 starting the add ons.
HAD'01 Ram 2500 SLT Laramie 4x1of2, 24v CTD, electric blue on silver 2-tone, matching blue spray-in bed liner, leveling spacers in front end, 3:55's, 'pork chop' tool boxes and tailgate box, back up/ work lights under rear bumper, On-board air, Roof mounted Air horns, Gauges in Pillar include Fuel PSI (pre & post filter), Oil PSI, Boost/EGT, Engine temp/Trans temp. BHAF, Edge EZ
Firestorm is offline
post #5 of 11 (permalink) Old 02-13-2011, 12:42 AM
Dodgefarmer's Avatar
I believe the computer will think that your factory tank is full until it starts dropping after the aux tank is empty and it will show miles to empty based on a full factory tank and your mpg. It will not know you have the aux tank. Basically your miles to empty will stay the same until the aux is empty and the factory tank starts empting.
singles club # 198
Dodgefarmer is offline
The Following 2 Users Say Thank You to Dodgefarmer For this addition to TDG:
buffalobob (02-13-2011), neeltburn (02-13-2011)
post #6 of 11 (permalink) Old 02-13-2011, 01:10 AM
ADMIN/MAFIA
neeltburn's Avatar
Very well put..
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 11 (permalink) Old 02-13-2011, 02:08 AM
On the fords if it stays of full to long it will throw a code due to thinking the fuel sender is messed up
2006 yamaha Vmax
2003 suzuki 1000 GSX-R
1993 F-250 460
Near GP alberta.
CC#58
budtoh3zo is offline
post #8 of 11 (permalink) Old 02-13-2011, 03:17 AM
Thats another reason to like our Dodges
singles club # 198
post #9 of 11 (permalink) Old 02-13-2011, 12:20 PM Thread Starter
buffalobob's Avatar
this is why my question. i had read this and didnt want the hastle
post #10 of 11 (permalink) Old 02-13-2011, 12:23 PM Thread Starter
buffalobob's Avatar
found some 45-49 gal aluminum on northerntool.com for $399 and a 90 gal for $449
Quick Rim Question? dcboyz 2003-2007 6.0L Power Stroke 4 11-09-2010 10:59 PM
hub quick question newtodiesel 2003-2007 6.0L Power Stroke 1 03-31-2009 09:48 PM
quick question newtodiesel 2003-2007 6.0L Power Stroke 5 01-09-2009 03:08 AM
Quick Question bad_cummins 5.9L Cummins (2003-2007.5) 10 02-20-2007 01:26 AM
quick question kkibbey 2003-2007 6.0 Tuner Forum 8 11-20-2006 06:20 PM
