What oil? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Diesel Dave 04, this thread has received 14 replies and been viewed 2196 times.
post #1 of 15 (permalink) Old 03-17-2011, 02:28 AM Thread Starter
Diesel Dave 04's Avatar
What oil?
Ok once im deleted, What oil should I use? I know there was talk that you can only run some special oil but I figure You can run what ever after you dont have a DPF. Is this true and what should I run?
Diesel Dave 04 is offline
post #2 of 15 (permalink) Old 03-17-2011, 02:35 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
10w40 syn, any brand you want... engine Oil and DPF deletes have nothing to do with each other
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #3 of 15 (permalink) Old 03-17-2011, 03:01 AM
ADMIN/MAFIA
neeltburn's Avatar
Oil Spec is 15W40. I personally Run Valvoline Premium Blue ( 15W40) With a Fleetguard LF16035 oil filter.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 15 (permalink) Old 03-17-2011, 10:02 AM
Super Moderator
4rcFed's Avatar
Images: 12
I've been running the Chevron Delo 15W40 with the Mopar (MO285) filter.
2008 Dodge 2500 Mega Ram, SLT, Powered by a little 'ol 408 cubic inch six cylinder!!!
Chrysler's warranty = Not worth the paper it is printed on!!!
Gone, but not forgotten!!!
1997 FORD F-250 HD
7.3L, XLT, Off-Road Package
3.55's, E4OD, 4wd, Dana 60 swap, 3" Sky RSK, 315/70/17's on Racelines.
4rcFed is offline
post #5 of 15 (permalink) Old 03-17-2011, 04:05 PM
HLC2239CUMMINS's Avatar
Rotella 15w40!
2010 6.7 cummins 4x4 crew cab short bed 6 speed auto 4:10 gears stock for now. Draw tite brake controller
HLC2239CUMMINS is offline
post #6 of 15 (permalink) Old 03-17-2011, 08:25 PM
2008 Dually Quad Cab, 6 Speed Auto 3.73, Edge W/Attitude,21/2" Hell bent Leveling Kit, Firestone Airbags, DIY Step Bars,EGR Delete, 4" Turbo Back Exhaust From K-2 Diesel, Cummins Mud Flaps,ATC Topper and Rhino lined rockers front to back
Rev. is offline
post #7 of 15 (permalink) Old 03-21-2011, 10:06 PM Thread Starter
Well I went with the Rotela 15W40 serviced the engine and the tranny, Had my welder buddy tig weld 2 bungs in the tranny pan for me one for the temp sender, and one for a drain.
I did not change the fuel filter, is there a trick to it or just spin it off. is there a spcial tool to turn it with. I could not get it to turn with a filter wrench and did not want to crack it.
I have a lift in my shop and it looks like a ***** to get to It must be even worse on the ground.If there is a special tool please let me know.
08 F-350 crew cab Lariat 4X4 Dually auto 4:10 gears.
rideing on Hankook Dyna pro AT's
post #8 of 15 (permalink) Old 03-22-2011, 12:40 AM
Dodgefarmer's Avatar
It is a ***** to change. And the trick is trying not to get diesel all over yourself. One hint is to attach a longer hose to drain port on the filter so it can be better directed away from you and into a pan. I attack it from both underneath and thru the fender well, not easy but doable. #@&*^
singles club # 198
Dodgefarmer is offline
post #9 of 15 (permalink) Old 03-22-2011, 12:44 AM
ADMIN/MAFIA
neeltburn's Avatar
It take a half in univeral and a long extenion... I liked doing it so much I put an Air Dog on mine... Not looking back either...
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #10 of 15 (permalink) Old 03-22-2011, 10:42 AM Thread Starter
Did you replace the whole thing with an air dog?
