6.7L Cummins Questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jeremiah, this thread has received 7 replies and been viewed 3487 times.
post #1 of 8 (permalink) Old 04-07-2011, 01:36 AM Thread Starter
Banned
!) How many head bolts per cylinder does the cummins 6.7L have.
2) How often does it go into regen?
3) How good are the 68RFE trannies with these trucks?
4) 3500 4x4 SINGLE REAR WHEEL Tow Rating & Payload Capacity
5) Is there a turbo boost gauge from the factory?
6) Do the heavy duties come with trailer sway control.
Anything I should know about the 6.7? Is there a way to have a high idle switch?
Jeremiah is offline
post #2 of 8 (permalink) Old 04-07-2011, 02:15 AM
1.) The same as any 5.9.
2.) As needed.
3.) Yes, but anything can be broken.
4.) The numbers are inside the drivers side door.
5.) I think that started this year.
6.) If it is not a factory option then the dealer will install.
Why would you want a high idle switch?
later is offline
post #3 of 8 (permalink) Old 04-07-2011, 02:24 AM
ADMIN/MAFIA
neeltburn's Avatar
26 Total
Depends on how its driven
I like mine. Depends on how its treated what kind of tune etc.. It can fail just ask Eazydeezy
Towing Spec
Not on the pre 2010s not sure if it has been added... Did you not test drive a 2010?
They have a rear sway bar... I tow and can't say there is much sway.
High idle is a factory option just make sure it is enabled by the dealer with the StarScan. You use you cruise control to turn it on or off. And you can raise and lower the RPM..
Don't idle it for long periods, don do a lot of stop and go driving, load it up and TOW.. WORK IT.. I also run my exhaust brake almost all the time, on a stock truck I would run it ALL THE Time.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 8 (permalink) Old 04-07-2011, 02:43 AM Thread Starter
Banned
Thanks, so I guess I have to ask, how many head bolts does the 5.9 have per cylinder?
Jeremiah is offline
post #5 of 8 (permalink) Old 04-07-2011, 02:52 AM
ADMIN/MAFIA
neeltburn's Avatar
26/6 = 4.33
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 8 (permalink) Old 04-08-2011, 10:35 PM Thread Starter
Banned
Originally Posted by neeltburn View Post
26/6 = 4.33
I didn't ask how many weeks in a month!
Jeremiah is offline
post #7 of 8 (permalink) Old 04-09-2011, 02:29 AM Thread Starter
Banned
26/6 = 4.33
So is that a problem since it is not 6 like the power stroke and duramax?
Jeremiah is offline
post #8 of 8 (permalink) Old 04-09-2011, 11:55 AM
ADMIN/MAFIA
neeltburn's Avatar
No not really... Drive Pressure seems to be a bigger concern.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
Cummins ISX Questions ??? HELP canucktrucks Medium and Heavy Duty 38 02-19-2012 05:59 PM
Cummins questions BEHR2010 5.9L Cummins (1998.5-2002) 39 08-03-2009 08:54 PM
New guy with a new 08 cummins, and dpf questions??? lakecummins 6.7L Cummins (2007.5-2011) 5 04-14-2008 04:58 PM
LB7 questions from a Cummins guy SixGunCummins Duramax 2001-2004 (LB7) 17 09-18-2006 02:49 PM
ISX Cummins questions bmoeller Medium and Heavy Duty 25 09-16-2006 03:05 PM
