Fuel Filter????? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by goatman1419, this thread has received 7 replies and been viewed 1751 times.
post #1 of 8 (permalink) Old 04-07-2011, 07:06 AM Thread Starter
Fuel Filter?????
Hey guys been gone a while since I did deletes. Truck runs awesome with no problems!!! Just replaced my CCV and addded the hose and filter from Glaicier. My question is what in the hell can I do to move/replace the stock fuel filter which is like being kicked in the nutts to change. I change mine every oil change so im getting pretty sore. The reaon I change mine so often is I had to replace injectors before on my 6.0 and that was like a kick in the butt. Thanks know ya'll can help.
goatman1419 is offline
post #2 of 8 (permalink) Old 04-07-2011, 11:53 AM
ADMIN/MAFIA
neeltburn's Avatar
Only way to move it is to go with an AirDon or FASS system. Changing ever oil change is over kill, every 10k would be fine. That is an expensive fuel filter to change that often.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 8 (permalink) Old 04-07-2011, 12:44 PM
HLC2239CUMMINS's Avatar
I change mine every 15000 and have never had a problem.
2010 6.7 cummins 4x4 crew cab short bed 6 speed auto 4:10 gears stock for now. Draw tite brake controller
HLC2239CUMMINS is offline
post #4 of 8 (permalink) Old 04-07-2011, 02:20 PM
Nadir's Avatar
The secondary 2um filter on my '07 has been on there for three years and over 30k miles. No pressure drop across it yet:
http://stuff.is-a-geek.net/PhotoAlbu...ics/CRD_32.JPG
The longer you run them, the better they filter.
Truck Pics:
Nadir is offline
post #5 of 8 (permalink) Old 04-08-2011, 07:49 PM
BigBlueDodge's Avatar
Get a airdog or fass they make it easy.
07 6.7
6 Inch lift
37-13.50 Nitto Mud Grapplers
XRT WOOO
Ts-mp8
S&B Intake
5 inch to 7 inch mitter cut stacks
egr all gone
2 10 inch mtx subs
Tint
Boost Fooler
Black Head and Tail lights
BigBlueDodge is offline
post #6 of 8 (permalink) Old 04-09-2011, 01:06 PM
buffalobob's Avatar
was it 2009 or 2010 that they changed the entire fuel filter setup to the top loading one similar to 2005 models. would this retrofit to a 2008 model. i asked cummins and got no answer. anybody have any ideas. those were a siomple change procedure.
2011 silverado lt, crewcab, short bed, 4X4, d-max/ allison
buffalobob is offline
post #7 of 8 (permalink) Old 04-25-2011, 08:54 PM Thread Starter
That would be awesome to go to the top model hope spmeone has that answer.
post #8 of 8 (permalink) Old 04-26-2011, 01:59 PM
buffalobob's Avatar
got a response from cummins. simply state they do not make a retrofit adapter and cannot advise changing the filter system. not a lot of help.
fuel pressure question? fuel filter or over flow valve? hereismylife 5.9L Cummins 12 Valve (1994-1998.5) 23 04-09-2010 12:33 AM
Aeromotive inline fuel filter canister with new filter for stage 2 and 3 fuel systems maxxis_mudder Ford Parts 5 09-08-2009 12:04 AM
Aeromotive aluminum fuel filter canister w/new 10 micron fuel filter and -10 adapter maxxis_mudder Whats Been Sold 0 02-13-2009 12:05 AM
Oil filter cap and fuel filter cap size Redleg 2008-2010 6.4L Power Stroke 7 02-09-2009 05:40 AM
oil filter/fuel filter housing droolinforparts 2003-2007 6.0L Power Stroke 16 03-06-2008 04:31 PM
