Update time and advice... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SOOTBANDIT, this thread has received 17 replies and been viewed 8094 times.
post #1 of 18 (permalink) Old 04-29-2011, 02:53 AM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Still hauling campers and boats and misc trailers all over the damn country and loving every min of it.
Except for these little demons that are starting to show there azz every once in awhile.
1. Transfer case replacement
2. Crank shaft position sensor
3. Water Pump
4. ABS Sensor
5. Ac Condensor
6. Evaporator
7. Accumulator
8. Ac Compressor
9 Orfice tube and line since its fixed
10. Other misc NORMAL wear and tear that i have failed to mention.
This all has hasnt happened at once but not to far apart just part of being on the road. Now for the advice part...My truck does not run hot empty loaded or unloaded normally between 190-205 on the water temp. But for some damn reason it sucks fluid out of radiator and into overflow tank but it wont return in a reasonable timeline into radiator (meaning i go from Indiana to Cali up and down elevation and it has overflowed once on me also just seems like it should pump back faster so i dont have to worry so damn much. Now i have changed Tstat, Radiator cap and it still doing this i have shutdown for the night and got up and top off radiator and left cap off and start truck no bubbles or anything so that makes me feel a little better bout the issue being a hg issue. I also have no water in oil and i have had the coolant testing and no carbon found in it so wat gives???? If i have lost you im sorry if you all think im just worry to damn much buy me a beer toi ease my nerves but this truck pays for itself and puts the bread and butter on table if you know wat i mean
Military Quote Of The Year
SOOTBANDIT is offline
post #2 of 18 (permalink) Old 04-29-2011, 03:46 AM
ADMIN/MAFIA
neeltburn's Avatar
Brandon, i have been thinging about this, I think its time to do a complete cooling system flush. Also remember to bleed the system via the stand pipe for the egr cooler as it is the high point of the cooling system. If you do not get the air out at that point it will have air pockets. (i know your cooler is deleted but it is still the high point)
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
SOOTBANDIT (05-07-2011)
post #3 of 18 (permalink) Old 04-30-2011, 04:03 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
i tested my coolant for exhaust gasses and had no luck
are the rad hoses/coolant overflow tank staying pressurized overnight? thats a pretty good indicator of a blown HG...
it might not be a bad idea to have the cylinders pressure tested... but doing a HG job on your truck would be much easier than it was on mine....
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
post #4 of 18 (permalink) Old 05-06-2011, 02:36 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
If the coolant tank/radiator are stating pressurized overnight to me and wat im being told would not be a hg issue...? It means its not leaking down which would be a good thing cause there may not be a leak at all. So it started to come back down as i go in lower elevation so i think im safe there but i still wanna know bout this gurggling and bubbles blowing in my overflow tank it does it non stop???? Come on guys put your 2 cents in and give it to me not going to hurt my feelings
post #5 of 18 (permalink) Old 05-07-2011, 12:28 AM
Dodgefarmer's Avatar
Soot,
Here's my $.02 or less. Check the overflow hose between radiator and tank, check for kinks, collapse or pin hole/crack. It could flow under pressure but upon cooling down and a vacuum trying to pull fluid back to radiator the hose could collapse or pull air thru a pin hole or crack. Sometimes its the simple things that can cause
How many miles a month are you doing now per month?
What part of Cali were you in?
singles club # 198
Dodgefarmer is offline
The Following 2 Users Say Thank You to Dodgefarmer For this addition to TDG:
CANYONBIKER (05-07-2011), SOOTBANDIT (05-07-2011)
post #6 of 18 (permalink) Old 05-07-2011, 04:09 AM
ADMIN/MAFIA
neeltburn's Avatar
also as I have said try bleeding air our via the stand pipe until coolant comes out air will go to the highest point of the cooling system.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 18 (permalink) Old 05-07-2011, 01:27 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Originally Posted by Dodgefarmer View Post
Soot,
This one has gotten me baffled. Im outting right around 15 to 20k a month on it and i have been to San Diego a couple times and bout a 100mi north of Sac and been to San Fran also. Where you at next time ill drop by
post #8 of 18 (permalink) Old 05-07-2011, 02:02 PM
CRAZY CANUCK
Maybe the cummins and duramax are different this way but when I blew my HG's the coolant system was bubbling/gurgling, i was blowing coolant out the over flow and the coolant system stayed pressurized over night, and I dont mean a little pressure, I mean ALOT of pressure... the engine temp was changing wildly as well... from little temp to extremely high temps, duno if thats what your symptoms are but it kind of sounds that way...
Ridin Dirty Club #5
TDG TOTQ
post #9 of 18 (permalink) Old 05-07-2011, 02:08 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Ya didnt mean you kinda come out and say your wrong sorry.
http://www.cumminsforum.com/forum/6-...you-judge.html
I dont like any of there replies except for one pretty much wat neel and dodgefarmer said so im going to give it a try
post #10 of 18 (permalink) Old 05-07-2011, 02:22 PM
CRAZY CANUCK
Well you can try bleeding the air out of the coolant system, but If it continues to do it then I would say its the HG, I know how you feel... "it HAS to be something simple" I even changed my rad cap.... no such luck, when we pressure tested my cylinders in my Dmax we only found a very small leak in one cylinder, once we pulled the heads 4 of the fire rings on the HG had been blown...
At least with a cummins the head is in plain sight, my truck they heads are burried... took over 20hrs to rip it apart and fix it, Im so happy that I know mechanically inclined people, saved me about $3500
Ridin Dirty Club #5
TDG TOTQ
Advice on next upgrade... one step at a time sunburnpoptarts LLY Tuner Forum 21 05-09-2010 11:23 PM
vendors advice and expert advice needed silverpeteok 5.9L Cummins (1998.5-2002) 11 01-25-2009 10:08 PM
1'st time posting? 1'st time dodge diesel owner trikes 5.9L Cummins 12 Valve (1994-1998.5) 18 07-22-2007 01:24 PM
Long time Diesel driver, first time poster FireHunter Introductions 11 12-05-2006 07:00 PM
Hello, long time listener first time caller... Oliverpuller Introductions 14 11-16-2006 08:08 PM
