Code problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Pauns08, this thread has received 9 replies and been viewed 1225 times.
post #1 of 10 (permalink) Old 05-07-2011, 07:41 PM Thread Starter
Code problem
I have a 2008 6.7 with edge racing juice, afe intake and 4" flo pro turbo back straight pipe and it keeps popping up three codes there the exhaust gas temperature bank 1 circuit 1, 2, & 3 can anyone tell me how to solve this problem? Also my truck has a loud annoying turbo whistle and it runs hotter than normal. Help lol
Pauns08 is offline
post #2 of 10 (permalink) Old 05-07-2011, 09:45 PM
ADMIN/MAFIA
neeltburn's Avatar
Sounds like your Simms have failed in the exhaust for your deletes.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 10 (permalink) Old 05-07-2011, 09:50 PM Thread Starter
What are simms? The only thing I had to plug into my nw exhaust was the two o2 sensors, is that what your talking about that may have failed?
Pauns08 is offline
post #4 of 10 (permalink) Old 05-08-2011, 03:08 AM
ADMIN/MAFIA
neeltburn's Avatar
You did not have to plug a "fooler" aka simm into the factory truck harness for the pressure sensors for the exhaust? I thought all the Juice/Edge deleted truck ran them..
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 10 (permalink) Old 05-08-2011, 03:23 AM Thread Starter
The only thing I put back into my exhaust was two o2 sensors, are the simms something that goes into the exhaust also? I'm fairly new to this but I ordered my exhaust with bungs and it came with two holes for the o2 sensors was all I saw.
Pauns08 is offline
post #6 of 10 (permalink) Old 05-08-2011, 03:51 AM
ADMIN/MAFIA
neeltburn's Avatar
The sims plug into the wiring harness on the truck that had temp sensors in the factory exhaust. the sims tells the ecm that the temp is the in the parameters to keep the CEL off and the truck out of regen. It was my understanding that the Juice used those to keep the CEL off. I would call Edge and ask them at this point then.
You still have the hard lines connected right? If so those are DPF pressure sensors.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 10 (permalink) Old 05-08-2011, 04:27 AM Thread Starter
Thank you very much for this information, do you know how many sims I have to plug back into the truck? I have all the sensors that came out of my factory exhaust tucked up under my truck and zip tied so I need fooler plugs to put into them so the truck doesn't try to go into regen mode? It actually told me yesterday on my overhead console in my truck that my exhaust filter was 80% full and I stopped the truck and it was idling high and my egt was close to 600 degrees while idling so I pushed reset dpf data but it still runs at a high idle and hot the only thing it did was stopped telling me my exhaust filter was 80% full.
Pauns08 is offline
post #8 of 10 (permalink) Old 05-08-2011, 11:53 PM
ADMIN/MAFIA
neeltburn's Avatar
Since you are not running the simms that sounds like your problem. It could set the truck into limp mode. I am not sure about how many simms you need. Post in the Vendor section and Im sure someone will hook you up. Did you just do your deletes?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #9 of 10 (permalink) Old 05-09-2011, 12:09 AM Thread Starter
Yes I just did the chip and exhaust three days ago and it ran great for one day then started acting up. Thanks again for the help.
Pauns08 is offline
post #10 of 10 (permalink) Old 05-12-2011, 11:52 AM
3 simms and they should have came with the exhaust set up.
2008 Dually Quad Cab, 6 Speed Auto 3.73, Edge W/Attitude,21/2" Hell bent Leveling Kit, Firestone Airbags, DIY Step Bars,EGR Delete, 4" Turbo Back Exhaust From K-2 Diesel, Cummins Mud Flaps,ATC Topper and Rhino lined rockers front to back
Rev. is offline
Problem Code BigBlueDodge 6.7L Cummins (2007.5-2011) 9 02-15-2011 04:21 PM
C-15 cat..6nz code/problem !!! Help !! canucktrucks Medium and Heavy Duty 32 03-07-2010 12:47 PM
03 CODE Problem intimidtr3 5.9L Cummins (2003-2007.5) 2 09-01-2007 01:55 AM
engine code problem bigboy6.5 6.5L Diesel Engine 9 02-18-2007 03:34 PM
Problem Code Cluck25 1994-2003 7.3L Power Stroke 3 01-22-2006 01:17 AM
