clik clik - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dodgefarmer2, this thread has received 6 replies and been viewed 1252 times.
post #1 of 7 (permalink) Old 05-07-2011, 10:58 PM Thread Starter
dodgefarmer2's Avatar
clik clik
went to start truck and it clicked a couple times and started. was fine till today listened to radio for 5 hrs. same thing charged batterys for 20 mins started fine. codes p2509, p0513 are they due to low voltage. loadmeter said they were weak but not real bad. have the original batterys run their course?
08 dodge 3500 dually, quad cab, inferno red,6.7, 4x4, 6sp auto, rhino lined bed, b&w gooseneck turnover ball,full length fiberglass running boards (color matching),reese hitch.
MEMBER THE DUALLY CLUB #75
MEMBER THE AMERICAN CLUB #41
10,055,000.00 points approximately
dodgefarmer2 is offline
post #2 of 7 (permalink) Old 05-08-2011, 02:41 AM
Dodgefarmer's Avatar
Its due to low voltage. See this post https://www.thedieselgarage.com/forum...d.php?t=105880
The electronics are very sensitive to low volatage and will throw codes but the same batteries in an older vehicle will work just fine.
singles club # 198
Dodgefarmer is offline
dodgefarmer2 (05-08-2011)
post #3 of 7 (permalink) Old 05-08-2011, 03:06 AM
ADMIN/MAFIA
neeltburn's Avatar
I actually did new batteries in my rig this past winter (early), I could really tell when the heater block was cycling it was very obvious that the batteries were weak. It also didn't crank very fast. New batteries installed and all was right.. (they where pretty weak when I tested as well) I would give some new batteries a shot and see where you are.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 7 (permalink) Old 05-08-2011, 03:57 AM Thread Starter
are these batterys under warranty? less than 36000 miles, also have extended warranty.right at 3 years.
post #5 of 7 (permalink) Old 05-08-2011, 04:07 AM
ADMIN/MAFIA
neeltburn's Avatar
I just got new batteries, didn't try to get any sort of warranty but I was almost 10k over the 36K mark at that time..
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 7 (permalink) Old 05-08-2011, 04:08 AM
Probable not. If there was some prorated warantee it wouldn't be much especially when you can probably get a better price else where then from a dealer.
singles club # 198
post #7 of 7 (permalink) Old 05-08-2011, 04:23 AM Thread Starter
i have nothing against dealers, i just try to avoid them when possible because they usually charge more than i care to pay.
