Calling out ynot??? or whoever wants a shot - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SOOTBANDIT, this thread has received 32 replies and been viewed 6253 times.
post #1 of 33 (permalink) Old 05-30-2011, 02:41 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Over this potential head gasket issue. Its being discussed on here but mainly on CF. But ill explain so the truck is basically pushing coolant into my resevior loaded and only normally during hot weather but in my opinion not sucking it back in a timely manner (maybe me worrying to much) example left IN to ID rad was full and overflow was at cold level pulled a 36ft 5th wheel heavy13-15k at 65-70mph all the way few spots are 55 not many. The temp outside was prob 70-80 not to bad the water level did not move a 1/4 in untill i went over the Sisters in WY by Evanston then from Evanston she rose maybe 2in to Eden Idaho. Then i unload and head back to In to get a load going to Houston TX so i get loaded did exact same thing made sure rad was full and overflow was at cold level and then left it was hot and only got hotter going to down to TX made it to bout 90mi left and she got hot. Temp went to 225-235 so i pulled over to see if it would cool down and also my clutch fan kicked on and i looked at the water level it had rose bout 6-8in from IN to TX boarder and temp was around 90-95 it did not actually boil over but to close for comfort it has boiled over twice but those 2 times it did not register hot. Temps run ok bout 190 empty and between 190-200 depending on hills loaded. So i have changed numerous thermo stats, and rad caps as of now they have factory oem installed. i have flushed my coolant and rad the best i can and put new fluids in and i changed my hose from overflow to rad thinking it might be collapsing on me during pulls and i have replaced all other hoses top and bottom. I prob have for got to mention something to you but i could use your advice you seem very intelligent in the heavy duty section this is smaller so should be walk in the park for ya. So do you actually think it is a head gasket??? Oh and i have been informed this truck has a multi layer gasket and since this all started ther has now been over 45k of loaded miles and it had not gotten worse truck is an 07 Dodge Cummins 6.7l Thanks again
Military Quote Of The Year
SOOTBANDIT is offline
post #2 of 33 (permalink) Old 05-31-2011, 01:13 AM
Dodgefarmer's Avatar
Soot,
Just wondering does your coolant temp drop after reducing load on engine such as after cresting a hill. The reason I ask is today coming home towing my 5th wheel(12,000lbs) was climbing a 10% grade in 2 and 3rd gear because of the 15 - 20 mph curves. Outside temp was only in the 60's but my temp climbed to 220-225 and fan kicked on which I think was because of the slow speed and not enough air over radiator. After over the top of grade, temp went down and fan disengaged. Of course I never stopped to check water level and I never have added water to radiator except when water pump went out.
I know you have been fighting this issue, hopefully its not a big deal.
singles club # 198
Dodgefarmer is offline
post #3 of 33 (permalink) Old 05-31-2011, 01:41 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
how hard is it to change the HG on a cummins? it would probably take a good day to change it....
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #4 of 33 (permalink) Old 05-31-2011, 01:58 AM
ADMIN/MAFIA
neeltburn's Avatar
It doesnt take long, but i would have the head decked for true and that takes time. Prolly 16 hrs you could have it off and back on in that time. I did a 12v in 12hrs id say but we did not have the head surfaced. For what Brandon is doing I would with out a doubt have the head sent to a machine shop. I would also look at doing ARP 625s and possibly a EGW or an aftermarket turbo to get the drive pressures in check. The stock VGT does not run at a 1.1 ratio.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #5 of 33 (permalink) Old 05-31-2011, 01:36 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Originally Posted by Dodgefarmer View Post
Soot,
Ya it does basically wat you just described to me wat yours did. I think the biggest reason im not going to change the hg is due to the fact of if i do and wat if it was not the problem in first place....I will just continue to drive it normally and monitor fuel mileage, temps, and water usage bout all i can do cause im just tired of it nickel and diming me to death lol. It just sounds like a problem child as my dad was saying other night caould be one of those no matter how much money you throw at it wont help so i better get to choppingwood so i can have a new truck
post #6 of 33 (permalink) Old 06-04-2011, 04:15 AM
ADMIN/MAFIA
neeltburn's Avatar
Im really thinking about posting some pics in here... for you Brandon..
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 33 (permalink) Old 06-07-2011, 01:36 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Just hold on lol dont have any deals yet.... Could a mod put this in the heavt duty section for me?
post #8 of 33 (permalink) Old 06-07-2011, 03:28 PM
ADMIN/MAFIA
neeltburn's Avatar
Since it is a b series cummins question in the dodge application lets leave it here Brandon. If there is someone you want to ask, why dont you pm them.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #9 of 33 (permalink) Old 06-09-2011, 05:20 PM
The other guy
OK bud. First thing is to do a bottle test. When you pull a hard grade with a big load, especially if the fan kicks on, immediately pull over and pull the overflow tube off the reservoir, stuff it in a clear soda bottle 3/4 full of water, plug off the inlet in the reservoir, rev it up a couple times if you can, and look for bubbles. If it has bubbles, pull the head. If it doesn't, check the rad with a heat gun for cross flow, should be 18 to 25* dif. If it's less than that thermostat is stuck. If it's more rad is plugged. Before messing with the heat gun fixes, check water pump pressure. Spec should be in the book or someone will post it. My books are stored away. If pressure is low, check the hoses for a collapsed hose first, then think about pullin the water pump and check the impeller for erosion and a lose press fit. That should get you started
ynot is offline
post #10 of 33 (permalink) Old 06-11-2011, 04:05 AM
It was 103 here on tuesday I was bucking a 45 mph wind with a 8.5'X22' enclosed trailer with a 9000# laod @55-65mph my temp was between 200 and 212 as soon as I turned back north and was cutting that wind cross ways it dropped back off 195-200.
Im with you on the nickle and dime Im gonna run this thing like i do everyday untill it pukes, and just bite the bullet on a new one! The LIL tugger has170000mi
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
single shot-split shot balz out 1994-2003 7.3L Power Stroke 24 07-30-2009 07:49 PM
split shot single shot ???? Macktruckdriver 1994-2003 7.3L Power Stroke 15 11-24-2007 04:10 AM
