MPG help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Diesel Dave 04, this thread has received 8 replies and been viewed 1843 times.
post #1 of 9 (permalink) Old 07-02-2011, 04:17 PM Thread Starter
Diesel Dave 04's Avatar
MPG help
Ok im running 6.7 auto 4:10 gears towing 16K 40 foot fifthwheel.
I just ran from PA to SC to myrtle beach and I expected more MPG.
I ran 68-70 MPH Im deleeted running the smarty JR on Tow. my one tank where I ran 70 most of the time and never droped out of 6th gear it got 8.97
then i had my best tank at 10.3 I would have thought my worst tank would be 10.3
Im going back on the same trip the end of the month and Im thinking of running it on stock power level do you guys think it will help?
08 F-350 crew cab Lariat 4X4 Dually auto 4:10 gears.
rideing on Hankook Dyna pro AT's
Diesel Dave 04 is offline
post #2 of 9 (permalink) Old 07-02-2011, 05:38 PM
ADMIN/MAFIA
neeltburn's Avatar
Did you have a lot of wind on this trip?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 9 (permalink) Old 07-03-2011, 12:49 AM
Dodgefarmer's Avatar
My guess is your not that far off. I pull a 12,000lb 36' trailer and do 10.3 but thats up and over mountains with a stretch of 8-10% grades and 15-20mph curves on the grades. Generally keep it at 60mph. Can do 12 on the flats.
Is your trip flat lands or hills? You are doing 70mph, 16k lbs and a dually with 4.10 gears. All three of those hurt your mileage compared to my truck. Have you tried keeping it 5th, while towing that kind of weight might help mileage and save the tranny, (See my 68rfe problem thread)
singles club # 198
Dodgefarmer is offline
post #4 of 9 (permalink) Old 07-03-2011, 01:51 PM Thread Starter
no, no bad head winds
post #5 of 9 (permalink) Old 07-03-2011, 02:05 PM Thread Starter
the trip is 90% flat the funny thing was i got better mpg when i was on the hilly section. and when i ran 65-68 seamed to help. once i broke 70 it droped bad.
I did see your 68RFE post I think if i get to 100K I will be getting a newer truck or pulling it for new clutches. What I was told by ATS was not to run the higher gears 5th and 6th below 1600 rpm. when you are loaded.
they set it up to hold 6th down to 1000 rpm and the pump dont have enough rpm to keep enough pressure to hold the clutches when you are loaded. and then they slip. once that happens a few times they glaze and it is all over.
but what do you guys think will the stock power setting help MPG or do you think I just need to run 65 MPH
post #6 of 9 (permalink) Old 07-04-2011, 03:59 AM
ADMIN/MAFIA
neeltburn's Avatar
I will see if I can find it again but cummins has a MPG bulletin out there and it explained MPG percentage loss after 55mph. I have tried this, when I left the smokies last year I ran 55mph through the mountains and broke 13 mpg. when I got closer to home I ran the speeds up to about 75 + or - a few MPH and I got 10.1ish mpg.. Mind you I have 3.73s and figure the toyhauler to be at about 10,500 lbs. Try running 55 on a trip and see what kind of mileage you get. Remember not to also let the motor lug. I am not sure that you will see a gain going back to a stock power setting. I think speed combined with weight will be the biggest factor.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 9 (permalink) Old 07-04-2011, 03:48 PM Thread Starter
I dont think i can do 55, Maybe I will try to run 63-65 I think your right the speed is everything. Maybe I should try the 40HP setting it is made for MPG right?
post #8 of 9 (permalink) Old 07-05-2011, 01:34 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
try the 40hp and keep your speeds down, that should help you a lot to get better mileage, also slower acellerations will help as well, try to keep the RPM's under 2000rpm
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #9 of 9 (permalink) Old 07-05-2011, 03:18 AM
ADMIN/MAFIA
neeltburn's Avatar
I saw an increase from the 40hp tune to the 70 hp tune, it is worth a shot though Dave as it only takes a few min, to load the tune. Give it a go, your results could turn out different than my results.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
