Mass air flow sensor/exhaust break - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rev., this thread has received 5 replies and been viewed 11570 times.
post #1 of 6 (permalink) Old 07-20-2011, 05:04 PM Thread Starter
Anybody having problems with hitting 100k miles and mass airflow sensor code coming up?
2008 Dually Quad Cab, 6 Speed Auto 3.73, Edge W/Attitude,21/2" Hell bent Leveling Kit, Firestone Airbags, DIY Step Bars,EGR Delete, 4" Turbo Back Exhaust From K-2 Diesel, Cummins Mud Flaps,ATC Topper and Rhino lined rockers front to back
Rev. is offline
post #2 of 6 (permalink) Old 07-21-2011, 01:02 AM
Dodgefarmer's Avatar
Nope, 108,000 miles.
singles club # 198
Dodgefarmer is offline
post #3 of 6 (permalink) Old 07-21-2011, 02:29 AM
ADMIN/MAFIA
neeltburn's Avatar
Do you have a CAI or oiled filter and have recently cleaned and oiled it?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 6 (permalink) Old 07-21-2011, 12:59 PM Thread Starter
Yup! K&N drop in cleaned it 8k back, pulled the MAF and I think the VAF yesterday and cleaned with electronic and parts cleaner and tried to clear the code and it came back. I did it several times, clearing the code that is. Would that also have cause my e brake to stop working?
Rev. is offline
post #5 of 6 (permalink) Old 07-21-2011, 02:06 PM
ADMIN/MAFIA
neeltburn's Avatar
The only time i have heard of exhaust brakes failing is when turbo veins get stuck for egr residue. Since this happened when you got the code my guess is your MAS has caused it. I would try replacing the MAS and see if the code goes away and eb works.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
Rev. (07-23-2011)
post #6 of 6 (permalink) Old 10-23-2011, 06:04 PM Thread Starter
Exhaust break
I was checking fuses the other day and found the #37 fuse blown. I thought that since the light was coming on at the switch that the MAF sensor had some to do with the break not coming on NOPE! all is good now but I still cannot get rid of the MAF code with a new MAF sensor installed.
Rev. is offline
mass air flow sensor mach1miles 2003-2007 6.0 Tuner Forum 4 09-12-2010 03:10 PM
How to test the Mass air flow sensor? whanner 2003-2007 6.0L Power Stroke 1 09-03-2010 01:15 AM
Mass air flow sensor hackshack 2003-2007 6.0L Power Stroke 5 01-02-2009 12:25 AM
Mass airflow sensor 03cmmns 5.9L Cummins (2003-2007.5) 4 05-31-2007 02:08 AM
mass air flow imported_diesel71 2003-2007 6.0L Power Stroke 6 05-28-2006 12:55 PM
