DPF DELETE PROBLEMS - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by HUMMINCUMMINS, this thread has received 4 replies and been viewed 9564 times.
post #1 of 5 (permalink) Old 09-09-2011, 03:57 AM Thread Starter
HUMMINCUMMINS's Avatar
DPF DELETE PROBLEMS
I just bought a 2009 mega cab. It has a black maxx chip and other go fast parts on it. It has the dpf delete on it. The problem i am having is that the odometer display keeps saying (dpf full). I took it into the shop and they reprogramed the chip to tell it it has the dpf delete but it still didnt take away the warning. Is there any thing that i can do to clear this up or fix the problem? Any help would be appreciated.
HUMMINCUMMINS is offline
post #2 of 5 (permalink) Old 09-09-2011, 04:08 AM
ADMIN/MAFIA
neeltburn's Avatar
Clear codes with the tuner and see what happens.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 5 (permalink) Old 09-09-2011, 02:51 PM Thread Starter
I cleared the codes and about the time i thought it cleared up the engine light popped up and it said dpf full. Same thing it has done and been doing
post #4 of 5 (permalink) Old 09-09-2011, 03:17 PM
ADMIN/MAFIA
neeltburn's Avatar
I would contact HS and see what they have to say. It sounds like there is something going on in the Black Maxx. Is it a check engine light or and overhead warning?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 5 (permalink) Old 09-12-2011, 02:33 AM Thread Starter
THE ENGINE LIGHT COMES ON AND ON THE ODOMETER IT SAYS DPF FULL. AND ON THE OVER HEAD DISPLAY IT SAYS SERVICE REQURED SEE DEALER NOW. NOW THE OTHER PROBLEM I RAN INTO IS OUT OF THE BLUE THE TRUCK DIES. IT WILL GO FROM 25 OR SO FUEL PSI TO 0. WHEN I GO TO RESTART THE TRUCK THE FUEL PUMP TAKES FOR EVER TO BUILD UP PRESSURE. IT IS A AIR DOG 165 GPH PUMP. I WENT THROUGH AND CHECKED ALL OF THE FUEL CONNECTIONS AND ELECTRICAL CONNECTIONS AS WELL. THEY ARE ALL HOOKED UP AND SEEM GOOD. AND WHEN YOU GET DOWN TO AROUND 1/8 TANK OF FUEL IT DIES FREQUENTLY. I NOTICED THAT THE SUCTION LINE TO THE FUEL PUMP IS TIED INTO THE SENDING UNIT. IS IT POSSIBLE FOR THE SENDING UNIT TO SET THE SUCTION TOO FAR OFF OF THE BOTTOM OF THE FUEL TANK? OR COULD THERE BE OTHER PROBLEMS THAT ARE GOING ON.
Inspection sticker problems for anyone with DPF Delete? yfz450_0569 6.7L Cummins (2007.5-2011) 1 06-19-2009 06:27 AM
Edge Juice, EGR Delete,SCT, Wheels & Tire, Liberator Egr Delete 760 PSD Whats Been Sold 3 04-22-2008 09:45 PM
Dfp Delete Mpg And Problems BRYANB2323 2008-2010 6.4L Engine Tuner Forum 1 03-14-2008 09:01 PM
Electrical problems/dash problems curtis2003 5.9L Cummins (2003-2007.5) 1 10-21-2006 08:27 AM
Problems with EGR delete procedure... Extended Power 2003-2007 6.0L Power Stroke 7 09-09-2006 02:53 PM
