68 rfe - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Diesel Dave 04, this thread has received 15 replies and been viewed 5695 times.
post #1 of 16 (permalink) Old 10-04-2011, 01:02 AM Thread Starter
Diesel Dave 04's Avatar
68 rfe
I now have 80 k on my 3500 i have a tranny issue when i pull out it shutters.
it has been getting worse and when i have the 5th wheel in tow it is worse.
it use to be it would shutter if i pulled out hard not it is even if i pull out easy with the trailer. and i had it start to shutter with a load in 6th going up a slite hill the RPM was at 1600 and it started to shutter so i quickly droped it down to 4th. i think it is the fwd. clutches.
08 F-350 crew cab Lariat 4X4 Dually auto 4:10 gears.
rideing on Hankook Dyna pro AT's
Diesel Dave 04 is offline
post #2 of 16 (permalink) Old 10-04-2011, 01:32 AM
Dodgefarmer's Avatar
Hate to say it.........
It sounds like the od clutches are slipping and are burn't.. See my 68RFE Problem thread. Tranny shop told me even when empty lock out od when driving at low rpms especially in city type driving.
singles club # 198
Dodgefarmer is offline
post #3 of 16 (permalink) Old 10-04-2011, 01:55 AM Thread Starter
Did yours shutter when pulling out? most times if i cannt keep it above 1600 to 1700 rpm i will drop a gear. i found that i get better MPG that way any way. mine has been shuttering when i pull out for a while but only if i pull out hard. now it is doing even if i try to pull out easy.
post #4 of 16 (permalink) Old 10-04-2011, 02:18 AM
ADMIN/MAFIA
neeltburn's Avatar
Dave,
Mike is prolly right but, Try reloading you smarty tune and see what happens. If you have Torque management bumped up drop it back to stock and see what happens.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #5 of 16 (permalink) Old 10-04-2011, 02:41 AM
No it did not "shutter" but at the slightest accelaration in 5th or 6th gear it would drop 1 or 2 gears and them sometimes hunt for a gear back and forth. To get it to up shift back up would have to cruise steady or even let off the throttle and coast a bit so it would up shift. When it got real bad it would not up shift to 6th unless I got it up to 80mph then let off the throttle.
singles club # 198
post #6 of 16 (permalink) Old 10-04-2011, 10:33 AM Thread Starter
I knew I should have went with a hand shaker, every truck I buy I say get a stick and every time i get the auto cause the wife says she wants to be able to tow the camper in a pinch. I checked the bord and did not hear any real issues with the 68 RFE so thought i was good. Oh well any one want a truck.
post #7 of 16 (permalink) Old 10-05-2011, 12:37 PM Thread Starter
Im looking for Disassembly and assembly instructions for the 68 RFE does any one have a file?
post #8 of 16 (permalink) Old 10-05-2011, 02:21 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
That sucks..i will be purchasing the ext warranty when that time comes in a few months lol
Military Quote Of The Year
SOOTBANDIT is offline
post #9 of 16 (permalink) Old 10-05-2011, 03:39 PM Thread Starter
Soot, I been reading every thing i can find about the 68RFE and the only thing i see is that the O/D clutches will go out if you lug it with a load in 5th or 6th. any other problems have been caused by People running lots of HP and torque through them. But I realy think with what i read about the AS68RC
tranny and them bumping up to 800 /FP torque that tranny should be in the 3500 truck also and the 68 RFE should be a 2500 tranny. Oh well i will be getting the Extreme Duty RAM 68 Super Master Combo Kit from www.transmissioncenter.net and i will build it myself.
post #10 of 16 (permalink) Old 10-05-2011, 05:16 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Ya i have heard of the problems so to speak. If i have the cash flow i will pay cash for extra warranty if not i will finance. But i will not keep this truck unless it has warranty lol I drive way to much and half the miles are empty and they are all way to abusive miles city/highway heavy/light but i always use the tow/haul mode and turn exhaust brake on except on slick roads learnt my lesson cleaned my shorts afterwards. My truck will 1 of a few trucks out there that are beat on a daily basis but well maintained i dont have a light right foot. I have read very little on theat other tranny you speak of as this is my first auto in a diesel...is that AS68RC in CC models?
