YAWNNNNNN - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dodgefarmer, this thread has received 18 replies and been viewed 5173 times.
post #1 of 19 (permalink) Old 11-22-2011, 03:03 AM Thread Starter
Dodgefarmer's Avatar
YAWNNNNNN
Man its been boring on this 6.7 forum. I guess no one is having problems with their 6.7 cummins .
I've got a turbo speed sensor code the comes and goes. When I get around to it, I am gone to change it out. No symptons that I can notice while driving. No pattern as to when it appears, sometimes at slow speed and other times on a hard acceleration, then goes off after a 1/2 to day later and stays off for couple to several days.
Like I said I'll do it whenever I get around to it.
singles club # 198
Dodgefarmer is offline
post #2 of 19 (permalink) Old 11-22-2011, 02:46 PM
ADMIN/MAFIA
neeltburn's Avatar
danger
DONT ASK FOR PROBLEMS MIKE!
But it does sound like your sensor is going..
PS if this was a 1/2 Dodge Gas Forum I could kept it hoping. in the last 4 months dads truck has got:
Waterpump
Timing cover gasket
Shift solenoids
Valvecover gaskets (need to do the other side yet)
and now its in for a lock cylinder for the ignition.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 19 (permalink) Old 11-24-2011, 09:28 PM
Those things are pretty pricey. Let me us know if you can find it at good price.
I've been having the issue the last 70K at 104K now.
2008 Dually Quad Cab, 6 Speed Auto 3.73, Edge W/Attitude,21/2" Hell bent Leveling Kit, Firestone Airbags, DIY Step Bars,EGR Delete, 4" Turbo Back Exhaust From K-2 Diesel, Cummins Mud Flaps,ATC Topper and Rhino lined rockers front to back
Rev. is offline
post #4 of 19 (permalink) Old 12-13-2011, 06:33 AM
#454
Motown Fire's Avatar
Yup, this forum is dead.......
2011 Dodge 3500 DRW CTD CrewCab 4X4 G56
2012 PJ 40' Dual Tandem Flat Bed
Motown Fire is offline
post #5 of 19 (permalink) Old 12-13-2011, 08:35 PM Thread Starter
I might be able to wake up this forum soon. Have an issue that just popped up last night at 117,325 miles. Getting a diagonosis right now...............
stay tuned.
singles club # 198
post #6 of 19 (permalink) Old 12-14-2011, 01:06 AM
ADMIN/MAFIA
neeltburn's Avatar
Rut row, whats it doing? Hope its nothing serious!
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 19 (permalink) Old 12-14-2011, 03:00 AM Thread Starter
Got to keep this forum active
Could be as simple as a bad sensor or........??????
Not jumping to conclusions or until I know the details. When I know then I will post.
singles club # 198
post #8 of 19 (permalink) Old 12-14-2011, 01:04 PM
ADMIN/MAFIA
neeltburn's Avatar
Keep us posted Mike!
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #9 of 19 (permalink) Old 12-15-2011, 09:31 PM Thread Starter
Up Date:
Last Monday just as I almost got home from a 350 mile freeway trip, 75mph all the way, my overhead lit up with: Catalytic(sp?) "Converter plugged up needs service". It did not say DPF plugged. Was driving completly normal up to now, 117,325 miles. With the overhead lit up power was cut back severly.
As I mentioned before my turbo speed sensor code (P2579) was popping up now and then so I thought this might be an issue causing problem. Replaced sensor ($294) and code went away. But then started getting P00F (fuel system over pressure relief) and a P1011 code(fuel pump psi too low). OK now lets change the fuel filter with new upgraded 5 micron filter ($35) and run it again. Runs fine under light load, but give a push on go pedal and catalytic plugged warning comes on again with reduction in power.
Been told that many times with emmision problems it will show the dpf or one of the catalytic converters as having problems. Now its been dropped off at the dealer and waiting for diagnosis. Hoping the diesel tech can get to it before he is off to 2 days of training certification to maintain his level IV certification required by Dodge.
singles club # 198
post #10 of 19 (permalink) Old 12-15-2011, 10:41 PM
southern-stroke
southern-stroke's Avatar
Send a message via MSN to southern-stroke
Sounds like time to delete it all and be done with it.
''Can You Keep Up?'' while I'm ''In The Passing Lane!''
southern-stroke is offline
The Following User Says Thank You to southern-stroke For this addition to TDG:
IdahoF350 (12-16-2011)
