Valve lash adjustment anyone? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kwik06ctd, this thread has received 4 replies and been viewed 3998 times.
post #1 of 5 (permalink) Old 12-27-2011, 03:57 AM Thread Starter
Has anyone had to do it yet? My rig's got 38k miles and I'm starting to hear some rocker noise especially at around 2k rpms. It's a stick and I use the jake break a lot. Could that be a factor? It's bad enough that I'm using the radio to make it go away for now. Could it be something else? Hope I'm just being paranoid, damn thing is so quiet compared to my 12v I find myself listening all the time. It's deffinatly a new sound.
kwik06ctd is offline
post #2 of 5 (permalink) Old 12-27-2011, 02:28 PM
Dodgefarmer's Avatar
I haven't heard of anyone needing to adjust valve lash, especially at low miles. I have 117,000+ miles and never adjusted and no noise yet. The service manual says: "The 24 valve overhead system is a low-maintance design. Routine adjustments are no longer necessary."
Not saying you need not to adjust, unless something unusual happened to your engine.
By the way you do not have a "Jake Brake", it is a exhaust brake, a totally different system.
singles club # 198
Dodgefarmer is offline
kwik06ctd (12-28-2011)
post #3 of 5 (permalink) Old 12-27-2011, 02:53 PM
ADMIN/MAFIA
neeltburn's Avatar
I wouldnt worry about it until at least 150k even then there are guys that have not did it. As Dodgefamer said its a low maintenace system. Also if you are deleted what you could be hearing is timing rattle.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 5 (permalink) Old 12-28-2011, 03:03 AM Thread Starter
Thanks guys. I am deleted. Can you tell me more about "timing rattle". What is going on, and how does deleting cause it. Can it be fixed or is there any need?
post #5 of 5 (permalink) Old 12-28-2011, 11:58 AM
ADMIN/MAFIA
neeltburn's Avatar
Timing rattle is a by product of added timing. Its just gonna happen when you add more injection timing.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
B series Valve lash adjustment BlowinSmoke 5.9L Cummins (Pre 1994) 14 04-25-2011 06:24 PM
24v standard procedure - valve lash adjustment triton 5.9L Cummins (2003-2007.5) 0 02-09-2009 07:57 PM
Valve lash adjustment Hardline 5.9L Cummins (2003-2007.5) 10 03-18-2008 11:52 AM
Valve Lash racehauler 1994-2003 7.3L Power Stroke 6 11-10-2006 03:49 PM
6.0's need a valve lash ajustment? fastback4 2003-2007 6.0L Power Stroke 4 11-10-2006 02:38 PM
