4WD Grinding - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 08'3500Mega, this thread has received 4 replies and been viewed 1175 times.
post #1 of 5 (permalink) Old 01-02-2012, 11:09 PM Thread Starter
4WD Grinding
I have an 08 with 95K. I have noticed recently that when I put it in 4 High there is a grinding from the front end when I am on the gas (sounds like metal on metal breaks). When coasting and it 2WD there is no grinding. I though that it might be an output shaft bearing or gears in the transfer case but they check out. Any ideas?
Thanks
08'3500Mega is offline
post #2 of 5 (permalink) Old 01-03-2012, 03:25 AM
ADMIN/MAFIA
neeltburn's Avatar
check the front U-Joints.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 5 (permalink) Old 01-03-2012, 04:38 PM
HLC2239CUMMINS's Avatar
What He Said !!
2010 6.7 cummins 4x4 crew cab short bed 6 speed auto 4:10 gears stock for now. Draw tite brake controller
HLC2239CUMMINS is offline
post #4 of 5 (permalink) Old 01-03-2012, 04:43 PM
Dedicated Diesel Perv
And after you check them, let us know what you find!
2018 Ford F250HD 6.7L
MoparBob is offline
post #5 of 5 (permalink) Old 01-05-2012, 12:45 PM Thread Starter
The front drive shaft was the culprit.
Here is what it was doing. In 2WD I could here a faint metallic chattering (Sounded like a dust cover on the breaks vibrating) in 4WD it sounded like breaks grinding. When I removed the drive shaft I found that the upper knuckle had a slight bind, when I tore it down I found that there is a non serviceable roller bearing that was completely dry. I picked up a drive shaft from the salvage yard and will rebuild the one that I have for a spare.
Help! 4x4 grinding sound BriteWhiteRam Duramax 2006-2007(LBZ & LLY) 8 03-15-2016 03:15 AM
grinding? mock12v 5.9L Cummins (2003-2007.5) 1 05-23-2011 01:55 AM
grinding noise.. Bcarriveau 2003-2007 6.0L Power Stroke 7 12-20-2009 01:10 PM
grinding noise cong 1994-2003 7.3L Power Stroke 4 08-02-2009 05:17 AM
