Programmer for 6.7L cummins and a manual trany - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Cummins0926, this thread has received 7 replies and been viewed 6769 times.
post #1 of 8 (permalink) Old 01-11-2012, 06:59 AM Thread Starter
I have an 09 dodge with the 6.7L and am looking to buy a programmer but a lot of them I read about mainly talk about automatic trany's but I have a 6 speed manual trany is there anything that I need to be cautious of or need to know about, & which one should I go with?
Cummins0926 is offline
post #2 of 8 (permalink) Old 01-11-2012, 08:33 PM
ADMIN/MAFIA
neeltburn's Avatar
It would be best if you told us what you do with the truck. Also do you want to deleted it or leave the DPF intact.
As far a the 6sp is concerned, your clutch will not hold a lot of abuse on higher tunes. You may even have to upgrade your clutch to hold the power of the higher tunes, (depending on which programmer you go with). Do you want Gauges or do you want a digital display? ( I prefer gauges to the display).
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
The Following 2 Users Say Thank You to neeltburn For this addition to TDG:
Bambi_basher (07-30-2012), Cummins0926 (01-12-2012)
post #3 of 8 (permalink) Old 01-12-2012, 12:25 AM Thread Starter
I plan on deleting the DPF when I can cuz I hate it.
Mostly I am looking to get better fuel millage, but also plan on buying a 5th wheel trailer.
I think I'm going to go with the H&S Mini Maxx.
As far as the clutch goes what do you suggest for it.
post #4 of 8 (permalink) Old 01-12-2012, 01:33 AM
ADMIN/MAFIA
neeltburn's Avatar
HS Mini max is a good tuner with a monitor. Also look at the Smarty Jr. ( You will need gauges with it)
Call South Bend and talk with them about clutches. How many miles do you have now. You may be good to go for a while if you stay with a tune under 100 horse.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 8 (permalink) Old 01-12-2012, 02:02 AM Thread Starter
I have around 56,000 miles on it right now, I try not to ride the clutch and don't over work it to bad.
post #6 of 8 (permalink) Old 01-13-2012, 02:09 AM
ADMIN/MAFIA
neeltburn's Avatar
I would expect your clutch to last a but longer as long as it is not abused on high tunes.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 8 (permalink) Old 10-12-2012, 02:25 AM
I second what neeltburn is saying. i just put the Mini Maxx in my truck. have not noticed any better fuel savings yet (only ran about 1/4 tank with it tuned) but i have been told that the 6.7 with the Mild tune (+60hp) runs about 2 mpg better. i like all the gages that come on the H&S. however if you like the old school look if real gages then go with a Smarty jr
2008 Ram 3500 6.7 6spd man
6" lift, Herd Areo LT Bumper
EGR/DPF Delete With 5" stright pipe
S&B Cold Air
H&S Mini Maxx
Bambi_basher is offline
post #8 of 8 (permalink) Old 10-14-2012, 03:55 AM
ADMIN/MAFIA
neeltburn's Avatar
Smarty Jr here on 70hp and I picked up about 4 mpg.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
Best Programmer for MANUAL Trans 6.0L rbelden 2003-2007 6.0 Tuner Forum 8 02-29-2008 05:00 AM
Best chip/programmer for Cummins Shadowskater Dodge Performance Forum 2 08-28-2007 02:39 PM
01 Cummins chip/programmer suggestions Diezel Dawg 5.9L Cummins (1998.5-2002) 6 06-14-2007 11:54 AM
Cummins Manual Ziggy8381 5.9L Cummins (2003-2007.5) 2 12-28-2006 05:25 PM
Auto trany, stalled out modded Cummins Smokem Dodge Performance Forum 9 05-04-2006 12:05 AM
