New injectors - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by HUMMINCUMMINS, this thread has received 6 replies and been viewed 1420 times.
post #1 of 7 (permalink) Old 01-24-2012, 03:19 AM Thread Starter
HUMMINCUMMINS's Avatar
New injectors
At around 23,500 miles the fuel pump went out on my 09 6.7. The dealership picked the truck up installed a new fuel pump. No sooner than they fired it up they say all 6 injectors went out. What could cause this to happen? I was wondering about sparatic fuel pressure from the bad pump. Or possibly getting the fuel system aired up? Or dirt or grit getting past the fuel filter? They had to replace the fuel bypass valve too. But while it is in their hands i cant get much input on the problem. Any info from any one would be nice!
HUMMINCUMMINS is offline
post #2 of 7 (permalink) Old 01-24-2012, 03:43 AM
ADMIN/MAFIA
neeltburn's Avatar
Fuel quality, water in the system many things can cause this. Are they going to warranty it? If so, Id let them foot the bill and go on. I have had 2 CP3 start leaking. I replaced the pump myself and put a AirDog II 100 in for better filtration. In your case with that few of miles I would wonder if you got a bad set of injectors. Also if so what additives have you ran?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 7 (permalink) Old 01-24-2012, 08:00 AM Thread Starter
Yeppp! Their payin for it. I havent ran any additives in the truck since ive owned it. But i dont know about the previous owner. I bought the truck used with 18.5k on it. It did have a airdog 165 gph fuel pump on it when i bought it. But they said that since they sold the truck like that they would fix it. I wondered about a bad set of injectors but all 6 at once? Is that really common?
post #4 of 7 (permalink) Old 01-25-2012, 03:19 AM
ADMIN/MAFIA
neeltburn's Avatar
Not at that mileage, so did they pull the AD? If so why?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 7 (permalink) Old 01-25-2012, 05:44 AM Thread Starter
Im not sure yet what they have used to fix the truck yet. Im 2000 miles away from home working. But i will find out this thursday night when i get home. They did say that the grand total for them is aroung 6 grand. But if it is a stock fuel pump it will be replaced with a fass first chance i get
post #6 of 7 (permalink) Old 01-27-2012, 10:30 PM Thread Starter
Well i sure lucked out. All 6 injectors. New sending unit. New fuel rail. New fass pump. All new fuel lines. New fuel bypass valve. 5 extra gallons of fuel. And they washed and detailed it. Truck runs alot better than it did before and mileage went up. They explained to me that the sparatic fuel pressure caused all the injectors to crack. So when they put the new fuel pump in it the truck flooded out and had a bad fuel knock. So they sought it best to replace all of the fuel lines and fuel rail because of damage it may have caused down the road.
post #7 of 7 (permalink) Old 01-28-2012, 11:26 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Well good to hear that makes 1 dealer that does there job
Military Quote Of The Year
SOOTBANDIT is offline
Looking for a set of 250 cc or bigger injectors in trade for my II 185 cc injectors mikes06lariat Ford Parts wanted 1 08-12-2009 02:52 AM
Performance Injectors Or Stock Injectors imported_Stroker01 1994-2003 7.3L Power Stroke 8 05-06-2008 04:16 PM
new injectors comanchejoe 7.3L and 6.9 IDI (Pre 1994) 7 01-06-2008 10:57 AM
Injectors bluovaltruk01 1994-2003 7.3L Power Stroke 7 01-02-2008 01:43 AM
DIY Injectors help Psd715 1994-2003 7.3L Power Stroke 13 11-29-2007 03:35 PM
