68 RFE Service - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by neeltburn, this thread has received 15 replies and been viewed 2995 times.
post #1 of 16 (permalink) Old 03-07-2012, 04:41 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
68 RFE Service
Next week I am going to be serviceing my 68RFE, I am using Mopar filters Valvoline ATF+4 and will be adding an AFE Power High Capacity Trans pan. I will post how it goes.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #2 of 16 (permalink) Old 03-08-2012, 01:18 AM
Dodgefarmer's Avatar
So...How many miles now? 60k?
Have fun getting the tranny fluid all over you
singles club # 198
Dodgefarmer is offline
post #3 of 16 (permalink) Old 03-08-2012, 11:51 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Doing on a buddys lift, ill be standing clear!
Sent from my iPhone using Tapatalk
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #4 of 16 (permalink) Old 03-08-2012, 03:59 PM
HLC2239CUMMINS's Avatar
Nothing like the smell of ATF 4 !!!!
2010 6.7 cummins 4x4 crew cab short bed 6 speed auto 4:10 gears stock for now. Draw tite brake controller
HLC2239CUMMINS is offline
post #5 of 16 (permalink) Old 03-08-2012, 05:46 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
About 200 miles away!
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 16 (permalink) Old 03-12-2012, 11:22 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Hell im bout ready for my 3rd service wanna do mine lol
Military Quote Of The Year
SOOTBANDIT is offline
post #7 of 16 (permalink) Old 03-13-2012, 12:00 PM
dodgefarmer2's Avatar
I need to start planning I'm at 38,000, what kind of cost for a do it yourself deal with pan. (new pan has a drain plug?)
08 dodge 3500 dually, quad cab, inferno red,6.7, 4x4, 6sp auto, rhino lined bed, b&w gooseneck turnover ball,full length fiberglass running boards (color matching),reese hitch.
MEMBER THE DUALLY CLUB #75
MEMBER THE AMERICAN CLUB #41
10,055,000.00 points approximately
dodgefarmer2 is offline
post #8 of 16 (permalink) Old 03-14-2012, 12:46 AM
New pan with drain plug still = oil dripping all over after pulling the pan off to get the filters changed. Seems like auto trannys drip oil forever even when draining with a plug. Plug just helps avoid the big splash . Still have to avoid the drips Anyway enjoy
Also sitting at almost 123,000 miles now.
singles club # 198
post #9 of 16 (permalink) Old 03-14-2012, 02:12 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
My afe pan was about 285 shipped. Filers were not bad but the 13 quarts of ATF+4 was 6 bucks a quart. Im doing it This weekend so I will report back with how it goes. And yes new pan has drain plug and gauge sender port.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #10 of 16 (permalink) Old 03-14-2012, 03:01 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Are u flushing the while tranny? There is a lil brass looking washer that can be a pain id it don't come out with the old foam filter just FYI
I am here: http://tapatalk.com/map.php?xu22jx
First Service Z71 4x4 Duramax 07.5-2010 (LMM) 10 11-03-2007 11:20 PM
6.7 service hvy 1ton 6.7L Cummins (2007.5-2011) 2 10-17-2007 11:19 PM
SEVERE SERVICE service? kenkillsr 2003-2007 6.0L Power Stroke 5 08-19-2007 05:06 AM
Cummins 6.7 L Service Bulliten "Re-Flash" SERVICE BULLETIN 18-033-07 REV.A Myguy 6.7L Cummins (2007.5-2011) 5 07-23-2007 02:00 AM
thanks for this service pigsbreath Ford Oasis requests 1 01-08-2007 02:01 AM
