Air leak?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by HUMMINCUMMINS, this thread has received 3 replies and been viewed 1506 times.
post #1 of 4 (permalink) Old 06-19-2012, 02:03 PM Thread Starter
HUMMINCUMMINS's Avatar
Air leak??
Ive got a air leak coming from my front end. I can hear it while driving and sometimes at a idle. The truck will only build 15 psi of boost because of this. Ive felt all the boots,along the intake elbow,seams on the intercooler and cant feel anything blow by my hand. Does anyone know of a way to for sure find the leak? Any advice and help would be greatly appreciated.
HUMMINCUMMINS is offline
post #2 of 4 (permalink) Old 06-19-2012, 02:33 PM
Dodgefarmer's Avatar
When checking for leaks are you able to load up the engine to get boost while checking for leaks? If its just idling or fast idle with no load probably no boost pressure to be able to feel for leaks. Just a thought.
singles club # 198
Dodgefarmer is offline
post #3 of 4 (permalink) Old 06-19-2012, 09:48 PM
ADMIN/MAFIA
neeltburn's Avatar
Check your intercooler boots.
Sent from my IPhone 4s An AT&T not so 4G phone via Tapatalk.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 4 (permalink) Old 06-20-2012, 04:49 AM Thread Starter
Well the boot coming off the intercooler to the boost tube had a thumb sized hole in the bottom side of it. I found a broken bolt that let the intercooler sag on the drivers side. So it ended up rubbing the boot on the air conditioner lines below it. Since its all H&S parts i got ahold of them and theyre sending a new boot on warranty and ive got to build some brackets to support my intercooler
OK fuel leak stopped now oil leak Stacked6600 1994-2003 7.3L Power Stroke 7 01-27-2011 03:37 AM
bad oil leak bcmueller 5.9L Cummins (1998.5-2002) 5 04-30-2010 02:41 AM
oil leak,,,, skydog 1994-2003 7.3L Power Stroke 5 01-31-2009 02:02 AM
1st oil leak imported_06F450 2003-2007 6.0L Power Stroke 2 10-01-2007 06:29 AM
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 04:17 AM
