exhast noise - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by King, this thread has received 6 replies and been viewed 1287 times.
post #1 of 7 (permalink) Old 06-29-2012, 03:40 AM Thread Starter
exhast noise
Im geting a weird noise though my exhaust sounds like the neigbor kids subwoofers. seems to be more freqent with eb on?
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
post #2 of 7 (permalink) Old 06-30-2012, 02:06 AM
ADMIN/MAFIA
neeltburn's Avatar
can you take a video and post it?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 7 (permalink) Old 07-06-2012, 01:24 AM Thread Starter
I took a video but the audio quality was terrible. I put my neighbors scanner on it and found that the vgt position percentage and all the vgt stats go all over the charts when it makes it weird noise. also tonight i had key on with engine off and could hear somthing cycling rapidly in the turbo did it for about 2 min. And the exhast brake opperats intermitantly, they both started at the same time so i assume they are related to the issue.
any thoughts would be appreciated.
King is offline
post #4 of 7 (permalink) Old 07-07-2012, 10:59 PM
ADMIN/MAFIA
neeltburn's Avatar
Could be the speed sensor in turbo, but thats a guess, I would pull the turbo and have it reworked. Rebuild kits are out there for the he351ve or you might find a used one somewhere. Call the injection shops in your area as I believe there exact specs vgts have to be set at to work right.
Sent from my IPhone 4s An AT&T not so 4G phone via Tapatalk.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
King (07-10-2012)
post #5 of 7 (permalink) Old 08-03-2012, 02:29 AM Thread Starter
I ended up having a new turbo put in.
King is offline
post #6 of 7 (permalink) Old 08-03-2012, 03:16 AM
ADMIN/MAFIA
neeltburn's Avatar
Glad you got it taken care of. Who did you take it too for the install? and how many miles were you at?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #7 of 7 (permalink) Old 08-04-2012, 03:15 AM Thread Starter
I did it with a freind who is a heavy truck tech just under 198000, however it left me stranded in a customers driveway with a no start on Thursday soi had it towed back found no fuel at the filter with key on and engine crank so we put in a new pump today fired right up. But as I was backing it out of the shop I noticed the programer display was blank. So I pulled back in wigged some wires by the programmer and truck died we can't get any communication with the ECM PCM I heard that the fuse box distribution box under th hood can be problematic but I have no wiring diagrams. I called on a new truck but don't know what I would buy they all suck.
King is offline
Here It comes the exhast retrofit! fjh Medium and Heavy Duty 28 05-05-2010 01:51 PM
5" FLO-PRO DPF back exhast and DPF delete pipe. SEABEE08FX4 Whats Been Sold 4 12-06-2009 02:28 PM
4 inch exhast turbo back KRDono Supporting Vendors Forum 1 04-12-2008 12:29 AM
exhast, pillar pod, gauges flyin05 Supporting Vendors Forum 1 10-14-2007 03:33 AM
Exhast brake for 2006 cummins 24Seven Supporting Vendors Forum 0 10-04-2006 10:13 PM
