Won't Start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Great White Hype, this thread has received 6 replies and been viewed 1967 times.
post #1 of 7 (permalink) Old 08-17-2013, 09:30 PM Thread Starter
Great White Hype's Avatar
Won't Start
So today was "work on the rig day." Changed the fuel filter, changed the oil, put some battery terminal protector on the terminals, cleaned the MAF's, and now it wont start. I finished all my work before I tried to crank it, and since I changed my fuel filter I knew it would take a couple of tries to get it to turn over. I may have cranked it a little long the first time. The second time it sounded tired and then after that it wouldn't barely budge, it would crank once, maybe and then nothing. Now it is all the way down to clicking.
I think it is the batteries (one or both) being dead. Both of them have about 12.3V-12.4V, then they drop to about 12.2V when I turn the key just to on. One drops all the way to around 5V when I try to turn it over and the other only drops to about 10V, and I don't see it drop below 11V when I have the multimeter across them both. Seems to me that the one dropping so low would be the dead one, that is also the one going directly to the starter.
I spilled a little bit of fuel onto the starter while I was changing the filter so I figured that might be part of the issue. I was getting 12V at the starter and it still wasn't going. I've tapped on it too in case the solenoid was sticking. There was a little bit of fuel under the cap on the trigger-wire connection but I have dried that out.
The wife is gone until tomorrow with the jumper cables. So I will have to wait until she gets back to try and jump it off to see if it is the batteries. Any other suggestions?
Great White Hype is offline
post #2 of 7 (permalink) Old 08-18-2013, 12:27 AM
Dodgefarmer's Avatar
The starter will pull a bit more from the battery that goes directly to it, shortest path, less resistance = more draw. How old are the batteries? These pickups need good strong batteries, soon as the drop off in voltage you get no start or various codes. The batteries would be fine in older vehicles that didn‘t have so much electrical demand.
singles club # 198
Dodgefarmer is offline
post #3 of 7 (permalink) Old 08-18-2013, 01:15 AM Thread Starter
They are both stock, its an '08, so right around 5 years old. I have had no issues with cranking before, even after fuel filter changes and running just the radio when camping or tailgating. I drove it to Autozone this morning to dump used oil!
post #4 of 7 (permalink) Old 08-18-2013, 01:50 AM
I would say 5 year old batteries are worn out for a diesel. I had issues when my battery voltage drop into the mid 12 volts. Put new batteries in and all was good again.
singles club # 198
The Following 2 Users Say Thank You to Dodgefarmer For this addition to TDG:
Great White Hype (08-18-2013), neeltburn (08-18-2013)
post #5 of 7 (permalink) Old 08-20-2013, 01:11 AM Thread Starter
Had the batteries load tested and they told me that both were shot. Two new ones in the truck and she started like a dream. Had the started bench tested too while I was at it. I figured one trip to the store instead of two.
Anyone know the torque specs for the starter and the brace that you have to take off to get to it? I used the specs from earlier models which was 32 ft-lbs, if I remember correctly.
Only problem now is that its throwing three codes -
U-0121
P-0513
P-2509
post #6 of 7 (permalink) Old 08-20-2013, 01:17 AM Thread Starter
P0513-invalid Skim Key
P2509-ecm/pcm Power Input Signal Intermittent
U0121 Lost Communication With Anti-lock Brake Module
Joy. No blown fuses and I can't tell if it is running any differently from the cruise around the parking lot.
I guess I'll find out on the way to work in the morning.
post #7 of 7 (permalink) Old 10-12-2013, 04:57 AM
When I changed my batteries bith times (run a lot of electronics converter lap top printer towing lift and of course radio beer drinking time on weekends!!) It threw same codes both times just cleared them with my chip orogrammer and never comes back.
goatman1419 is offline
C-15 won't start. Rat Fink Medium and Heavy Duty 15 04-18-2013 04:52 AM
HELP!!7.3 WON'T START j1586 1994-2003 7.3L Power Stroke 5 06-15-2011 06:39 PM
Won't start LKW Medium and Heavy Duty 8 01-10-2011 06:35 PM
Won't start! mckey73 Duramax 2001-2004 (LB7) 7 06-08-2009 05:56 AM
won't start 98 12-valve32 5.9L Cummins (1998.5-2002) 8 04-16-2008 01:08 AM
