Need input - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by [email protected], this thread has received 4 replies and been viewed 983 times.
post #1 of 5 (permalink) Old 09-29-2013, 04:05 AM Thread Starter
Need input
I just bought a toy hauler to pull with my 2007 3500 with a 6.7. It has 120,000 miles on it now and still runs good. The issue I have is the toy hauler weighs in at 18,000 lbs empty. According to the Dodge website my truck is rated at 15,050 max. It pulls the toy hauler without any trouble, but, I want to take the necessary steps to prevent any issues. Should I put a Edge Juice in it to increase the horsepower, and something to adjust the pressure in the transmission so the clutches will not slip. Any advise will be appreciated.
Thanks
John
post #2 of 5 (permalink) Old 09-29-2013, 07:10 PM
Dodgefarmer's Avatar
The easiest thing to do is install a Sonnax line booster. It just plugs into the wiring harness coming out of transmission. It increases the line pressure to the clutches for less slippage. I put one in in my 07.5 after I burnt the od clutches. It will feel like you have plenty of power in od but the line pressures are to low at lower rpm's when towing. Also do not tow that heavy in 5th or 6th gear. Both gears use the od clutches which are prone to slipping with heavy tows, low rpm in od.
singles club # 198
Dodgefarmer is offline
post #3 of 5 (permalink) Old 09-30-2013, 09:13 PM Thread Starter
Thanks Dodgefarmer for the info. What you said makes sense. I am ordering the transmission part this week. My next question is what programmer can I use? I called and checked on the Edge juice with attitude and was told you could no longer do the EGR cooler delete. I could however pay additional money and get the DPF delete and the pipe. I am looking for better fuel economy when towing, not trying to race the truck. In regards to the EGR delete I was told that I could remove the EGR cooler and my engine light would come on but it would not effect the engine. What is yo thoughts on all of this.
Thanks again
John
post #4 of 5 (permalink) Old 09-30-2013, 11:59 PM
Thanks again
John
I stayed stock, didn't use programmers, others here could give you better answers. Doing deletes/programmers in CA gets you in trouble with the smog cops.
singles club # 198
post #5 of 5 (permalink) Old 10-01-2013, 01:54 AM
ADMIN/MAFIA
neeltburn's Avatar
I wouldn't delete a leaf blower in CA... Pull that much weight Id stay stock and rock out the stock tranny then worry about it. I think your rig will be loaded fine.. I traded my fulled deleted on a 2012 6.7HO and don't miss it..
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
Need some input vcassens 2003-2007 6.0L Power Stroke 5 08-26-2010 04:43 AM
need some input conman3300 The Parking Lot 0 04-22-2010 10:02 PM
Need Help/input... Super 05 2003-2007 6.0L Power Stroke 16 03-23-2009 02:07 PM
need input on a 7.3 05dury 1994-2003 7.3L Power Stroke 29 06-04-2007 01:09 PM
