EGR question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by shiner1836, this thread has received 6 replies and been viewed 1231 times.
post #1 of 7 (permalink) Old 12-29-2008, 09:15 PM Thread Starter
EGR question
Ive got the egr blocker plates sitting at home, when I install these, will it throw my truck into limp mode or just throw the CEL. I dont have an insight or any other tuner on there so I want to makes sure it just throws the CEL if anything. the only mod on the truck is the DPR delete.
shiner1836 is offline
post #2 of 7 (permalink) Old 12-29-2008, 10:40 PM
MART5.9's Avatar
Should just throw a soft code. You`re better drive with the light on all time than with the EGR I know that for sure
2006 3500 mega cab SLT auto.
Diamond eye turbo back, S&B cold air intake,62mm turbo, billet tranny, smartyJR....
Proud to now participate to global warming
EGR and DPF are the worst CRAP ever and the worst is still to come.....UREA !
MART5.9 is offline
post #3 of 7 (permalink) Old 12-30-2008, 03:13 AM Thread Starter
Thanks! Went ahead and installed it anyway earlier tonight and was just crossing my fingers. That gives me the peace of mind I needed though!
post #4 of 7 (permalink) Old 01-01-2009, 10:58 PM
I am in the same boat but do I just need the block off plates or do I need the cooler delete too?
BigRed6.7CTD is offline
post #5 of 7 (permalink) Old 01-09-2009, 01:40 AM Thread Starter
I just ran the EGR blocker plates, the cooler delete was more than I wanted to get in to at the moment. Really a pretty easy install. Mind the screws on the butterfly valve in the intake though! i snapped both of them when pulling the valve plate out, no but deal since i got it out and dont plan on putting it back, WD40 that sucker tho!
post #6 of 7 (permalink) Old 01-09-2009, 02:23 AM
fuzzy's Avatar
Don't know if you guys are using the thin plates under the egr, or taking it off completly. If your using the thin plates and put your egr back on top of the plates, I recommend getting something to block the tube also. Over time even with the egr unplugged, it still gets forced open somehow, and you end up with a mess on top of the plates. I had the thin plates at first with nothing blocking the tube. I pulled the egr 4000 miles after that install, and it was full of black soot water, and the plates had sooty slime on them. Not really hurting anything but your egr if you ever need it again, but 79 cent 1 1/8" freeze plug blocking the tube will save you from the mess I had.
fuzzy is offline
post #7 of 7 (permalink) Old 01-09-2009, 11:24 PM
Ghost
Phily's Avatar
Every 6.7 owner should think like that.
Phily is offline
smarty question?? DMSMOKIN3500 5.9L Cummins (2003-2007.5) 19 01-11-2009 06:06 PM
4X4 question Rosco 2003-2007 6.0L Power Stroke 12 01-08-2009 06:20 AM
6.0 guy with a 7.3 question LovinPSDs 1994-2003 7.3L Power Stroke 13 01-05-2009 01:41 AM
injector question familymechanic 5.9L Cummins 12 Valve (1994-1998.5) 1 12-29-2008 11:13 PM
