Replacement Service 6.7L engine? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RacinDuallie, this thread has received 10 replies and been viewed 2007 times.
post #1 of 11 (permalink) Old 04-04-2006, 02:15 PM Thread Starter
Any info available on when we can expect to be able to get a 6.7L from a Cummins Parts Dealer ? : I hear they are only at 305Hp-610Tq. :shrug:
Wonder if a P-pump can be retrofitted to this new breed?:
How many are waiting to get their hands on one of these new engines?
RacinDuallie is offline
post #2 of 11 (permalink) Old 04-08-2006, 05:30 PM
TDG Mafia - Booze Runner
Snowaholic's Avatar
Chompin at the bit...........I'll probably give the new engine a year in service before I buy. Gotta baby the 7.3 until then:umno:
P-pump conversion, Nope, and I wouldn't worry about the current hp/tq ratings:secret: for now.
2007 Dodge 3500 MegaCab Laramie CTD 4x4 Patroit Blue Just a bunch of Go fast parts and programing
Snowaholic is offline
post #3 of 11 (permalink) Old 04-08-2006, 11:57 PM
Yeah, that would be a pretty hot motor to P-pump. I don't know anything really about these CR motors, is it an electronically controlled injector or does the rail regulate which injector sprays when? Cause if it is electronically controlled, it seems like it would be quite difficult to retro fit a p-pump on. unless a 24valve injector body would work, the motor seems pretty similar other than that crazy pump system.
post #4 of 11 (permalink) Old 04-09-2006, 12:13 AM
TDG Mafia 36
Diesel Fanatic's Avatar
Send a message via Yahoo to Diesel Fanatic
I heard the horse power and torque are going to be around 325hp and a little over 700tq, Pretty bad A... if you ask me. :agreed:
Brandon AKA bcumminsmeck
Diesel Fanatic is offline
post #5 of 11 (permalink) Old 04-09-2006, 02:12 AM
The output ratings are just staying the same for epa and legal reasons....like a month after its been out they'll up it underrating the engine just like they did with the old muscle cars.
Dom
Deezle1 is offline
post #6 of 11 (permalink) Old 04-09-2006, 06:17 PM
The 6.7 in some ag applications has a 12v head with a pump.
Jff24Gordn is offline
post #7 of 11 (permalink) Old 04-09-2006, 09:52 PM
Mafia member 46
There is a guy on TDR that P-pumped his CR engine, he used a custom front gearcase and custom fuel inj. lines. I believe he is using 24v injectors in it. As far as I can tell, the CR and 24V head are the same in regards to the injector installation, the CR just adds wiring in the valvecover.
Current: '07.5 2500 QC/SB ETJ/68RFE, 4x4, Fabtech 6" lift, KMC XD "Diesel" 20x10 wheels, Pro Comp X all terrain 37x13.5R20 tires, BDog P Pup AFE, MegacannonII, H&S Gen 1 DPF Delete, EGR unplugged. Dynoed 361hp/677tq 20090220
SOLD!'03.5 3500 SRW QC Dynoed 2/11/06 457hp/1002tq
Scrappy is offline
post #8 of 11 (permalink) Old 04-10-2006, 05:33 AM
thats what I thought, that makes a bit of sense, now my question is this, is a common rail, running a p-pump and 24valve injectors really much different than a p-pumped 24v. They are a really similar head, if there is any difference at all. Just curious, it would be sweet to do a p-pumped 6.7L though.
post #9 of 11 (permalink) Old 04-10-2006, 04:57 PM
Mafia member 46
Supposedly the CR head has better flow ratings on the valves.
Scrappy is offline
post #10 of 11 (permalink) Old 04-10-2006, 09:53 PM
GotTorque?'s Avatar
I just got in the new Truck Trend mag. and it says [email protected] RPM and 610 ft/lb [email protected] RPM.
2000 F-250
4x4 ECSB
4" DP - 5" Back - 8" Black miter
K&N Intake
Tony Wildman 6pos Chip
Stewart Warner Maximum Boost, Trans, Pyro
35" BFG KM MT's
Jensen 7" Flip out DVD/CD
10" Rockford Fosgate Subwoofer
2400w Rockford Fosgate Amp
Soon to come -
4"-6" Lift
HID's
05+Front end Conversion
Train Horns
GotTorque? is offline
