Need Help ASAP - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by towtruck, this thread has received 2 replies and been viewed 1556 times.
post #1 of 3 (permalink) Old 03-06-2014, 11:23 PM Thread Starter
Need Help ASAP
I need to know if a 2012 6.7 can be put into a 08 if all the stuff is swapped over like the Exhaust and sensors.
I have a 2008 Sterling Bullet 45 with 210k and i have a once in a life time op to grab a 2012 6.7 with 28k on it, But its the High Output motor, my Injectors took a **** and rather then spend over $3k for replacement i can spend alot less then that for this engine.
I only have till tomorrow to decide if i want this engine or not.
towtruck is offline
post #2 of 3 (permalink) Old 03-07-2014, 04:24 PM
Dodgefarmer's Avatar
Is the 2012 engine out of a 25/3500? Then you need to think about the tranny since your 4500 has the Asian trans if its auto and the 25/3500 use the 68rfe transmission. Besides that is I don't know if there is any differences in the dash electronics, got to assume they are same.
Are you looking for more hp or do you think you can do the swap cheaper vs. replacing the injectors figuring the time and effort to swap out the complete engine and maybe the trans?
singles club # 198
Dodgefarmer is offline
post #3 of 3 (permalink) Old 03-22-2014, 03:18 PM
ADMIN/MAFIA
neeltburn's Avatar
Tuning is diffenrent, you "MAY" be able to get it to work, but it would be way easier to just replace the injectors, if they didnt do any melting of pistons. There are several more sensors on the 4th Gens than on the 3rd Gens.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
NEED HELP ASAP powerstroke7.3 2003-2007 6.0L Power Stroke 6 12-02-2010 02:11 AM
need help ASAP!!! powerstroke7.3 2003-2007 6.0L Power Stroke 6 01-24-2010 06:33 PM
Need Help asap 01duramax6spd The Parking Lot 25 03-06-2008 11:52 AM
Help Asap!!! scottman70 General Ford Truck and Excursion 1 07-20-2007 02:58 AM
