2011 6.7L BLOWING WATER FROM SURGE TANK - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rmussey, this thread has received 5 replies and been viewed 1963 times.
post #1 of 6 (permalink) Old 03-27-2014, 04:07 PM Thread Starter
I HAVE A SCHOOL BUS THAT HAS LESS THAN 18000 MILES AND HAS STARTED BLOWING COOLANT FROM SURGE TANK OVERFLOW. I TOOK IT TO THE SHOP DUE TO NO CODES AND NOT OVERHEATING AND PRESSURE TEST CHECKED OUT OK. THE SHOP COULD NOT FIGURE OUT WHAT THE ISSUE WAS. THEY GAVE ME PAPERS TO SEND TO CUMMINGS TO DOCUMENT COOLANT LOSS. HAS ANYONE ELSE EVER HAD THIS ISSUE? I WOULD LIKE TO FIX IT BEFORE IT GOES OUT AND DOES GET HOT. THANKS TO ALL!
rmussey is offline
post #2 of 6 (permalink) Old 03-27-2014, 05:17 PM
First thing you need to check is the Rad cap if it is not holding preasure it will suck in air at the pump, it is a centrifical pump and without preasure the seal will unseat. The work order, you got should tell you if they checked it, if not phone them.
Just a thought!
Johnp3 is offline
post #3 of 6 (permalink) Old 03-27-2014, 05:51 PM Thread Starter
ACTUALLY I ALREADY DID THAT AND THE SHOP HAS AS WELL TO NO AVAIL THANKS!
rmussey is offline
post #4 of 6 (permalink) Old 03-27-2014, 06:12 PM
One other thing is after a drive of an hour or more, open the hood and see if the top rad hose is solid, it is posible the surge tank is leaking at the threads or top seams
Just a thought!
Johnp3 is offline
post #5 of 6 (permalink) Old 03-28-2014, 07:50 PM Thread Starter
It has new surge tank -due to recall- but this happens within 15 minutes of driving. it has not even warmed up good.
rmussey is offline
post #6 of 6 (permalink) Old 03-29-2014, 06:02 PM
On this site is Handy links in the search section do a complete bottle test, as much as it fits your unit, then talk to crysler again. If it only happens when it is cold then you have to take it to the dealer and leave it overnight. There is no use taking a truck in to be repaired for something that they can not duplicate, at the appointment time.
Just a thought!
Johnp3 is offline
Coolingmist stage 2 water/methanol with vari-cooler controller and 6 gal. tank tony597fitter Whats Been Sold 5 02-08-2008 05:59 AM
Coolingmist stage 2 water/methanol with vari-cooler controller and 6 gal. tank tony597fitter Whats Been Sold 0 12-24-2007 05:55 AM
Coolingmist stage 2 water/methanol with vari-cooler controller and 6 gal. tank tony597fitter Whats Been Sold 0 12-24-2007 05:54 AM
water blowing out of over flow under boost ram5.9cummins 5.9L Cummins 12 Valve (1994-1998.5) 1 10-25-2007 01:07 AM
Water/meth tank above nozzles? Cerebus 1994-2003 7.3L Power Stroke 7 05-10-2007 04:18 PM
