Rearend lube change - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by goatman1419, this thread has received 0 replies and been viewed 1536 times.
post #1 of 1 (permalink) Old 05-29-2014, 04:20 AM Thread Starter
Rearend lube change
Just wanted to give everyone a heads up. I changed my rear end fluid about 10,000 miles ago and started getting a shimmy in rear end after everything was good and heated up. it normally happened on left hand turns from a complete stop. didnt do it if I was rolling or going straight from stop. did some research checked everything. I finally drained the fluid (Castrol Syn) added a bottle of anti-slip fluid and replaced fluid. Shimmy left after about a 100 mile trip after additive. Like I said just a heads up might have been a dumb mistake not adding it but just wanted to save someone else the heart drop when it started shimmying.
goatman1419 is offline
What lube to use? pyro2nite 2008-2010 Body & Suspension 2 09-09-2010 06:09 PM
Opti lube LargeCar Bio-Diesel/ULSD/Additives Discussions 12 04-17-2010 05:56 AM
opti-lube strokin6L 2003-2007 6.0L Power Stroke 41 06-19-2009 07:49 PM
Opti-lube........... LargeCar The Parking Lot 1 04-01-2009 02:49 PM
Opti-Lube ?? haunruh General Diesel 0 06-09-2007 05:53 PM
