High Idle Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Sledpuller500, this thread has received 9 replies and been viewed 2039 times.
post #1 of 10 (permalink) Old 12-30-2008, 11:02 PM Thread Starter
Inline Junky!
Sledpuller500's Avatar
Images: 121
High Idle Question
In the 5.9 CR section we have been talking about the high idle function in our trucks. Alot say that with the most up to date smarty you can set your cruise controll and then bring the rpms up no mater what the temp. How ever this does not seem to work in a manual trans truck. Some one mentioned that the 6.7 guys were grounding a wire somewhere and that makes it work. Anyone know anything about that??
https://thedieselgarage.com/forums/showthread.php?t=749
Sledpuller500 is offline
post #2 of 10 (permalink) Old 12-31-2008, 12:41 AM
fuzzy's Avatar
Mastercaster is the man that needs to see this thread. But yes there is a wire somewhere under the hood right in behind the clutch somewhere in the firewall. Does that narrow it down for you. (HAHA). He will see it, and let you know for sure.
fuzzy is offline
post #3 of 10 (permalink) Old 12-31-2008, 04:19 AM Thread Starter
Inline Junky!
Images: 121
Well at least it can be done. I look forward to hearing about it!!
post #4 of 10 (permalink) Old 12-31-2008, 03:32 PM
i've got that info somewhere...just need to find it. but, no you don't have the wire to ground like we do on the 6.7. you have to jumper a pin on the ecm. i am pretty sure it's #22. and yes, you will be able to run it through the cruise control as we do. let me look for the specifics, and i'll jump back on here with them.
mastercaster is offline
The Following User Says Thank You to mastercaster For this addition to TDG:
Sledpuller500 (12-31-2008)
post #5 of 10 (permalink) Old 12-31-2008, 04:03 PM
you do have to ground pin#22 on your ecm. i know this works for the '05-'07 models. not positive about the '04. if you can get your dealer to enable it for free then it's worth trying anyway. the pigtail should run less than $10.
you need to install a pigtail on pin #22 on your ecm. Part #3824810 from your Cummins dealer.
Undo the ECM connector from the ECM. Use a paper clip, push it through PIN #22 from the engine side to get the orange rubber plug out. Remove the nut from the ground, You'll see the ground right next to the where the connector plugs into the ECM. connect some extra wire to the pigtail you bought, and a ring terminal. Connect the ring terminal to the other side. Push the pin on the cummins part into port #22 on ECM wire harness. Should be to the right of a black wire on the connector. ground the ring terminal. have your dealer enable the "fast" or "high" idle feature.
post #6 of 10 (permalink) Old 12-31-2008, 04:55 PM Thread Starter
Inline Junky!
Images: 121
Great!! Mines an 04.5 so i think it will work. Ill try after work!
post #7 of 10 (permalink) Old 12-31-2008, 09:31 PM Thread Starter
Inline Junky!
Images: 121
THIS WORKS PERFECT!!!!! Thanks ALOT Mastercaster!!!!!
post #8 of 10 (permalink) Old 12-31-2008, 10:19 PM
sweet!! good to hear. enjoy it. i use mine all of the time. heats things up much faster in the cool months, and keeps the a/c nice and cold in the hot months when idling. not to mention, decreasing or eliminating the soot and wet stacking.
Sledpuller500 (01-02-2009)
post #9 of 10 (permalink) Old 12-31-2008, 10:42 PM
ADMIN/MAFIA
neeltburn's Avatar
Sledpuller
Im glad you got the info you needed. I figured someone would know on here.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #10 of 10 (permalink) Old 01-02-2009, 02:04 AM
2nd Gen Guru
Mopar1973Man's Avatar
I'm years behind you all but I've got high idle that works like a dream...
http://mopar.mopar1973man.com/tips/c.../high-idle.htm
But I know there is some serious differences between my truck and yours but the high idle function might be easy to fool and kick on when you want it... But who knows...
Mopar1973Man is offline
high idle help lilrebeljames 5.9L Cummins (2003-2007.5) 20 01-03-2009 04:06 PM
Bill/Bcarriveau, hi idle? SSpeeDEMONSS 2003-2007 6.0L Power Stroke 6 01-01-2009 09:32 PM
High Idle & High Idle Kicker... Mopar1973Man 5.9L Cummins (1998.5-2002) 4 12-25-2008 01:36 PM
Upfitter Switches & High Idle machine Ford - Modification instructions, Product installs and Tech Articles 0 12-23-2008 03:09 AM
05-06 High Idle mod Bcarriveau Ford - Modification instructions, Product installs and Tech Articles 0 12-23-2008 02:47 AM
