AC problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by goatman1419, this thread has received 2 replies and been viewed 1639 times.
post #1 of 3 (permalink) Old 10-24-2014, 07:53 PM Thread Starter
AC problems
Started blowing hot air yesreday so I went and bought a refill kit and heres my problem. Hooked it up and needle read around 100 which is in the red. My compressor is engaged but you cant adde to it if its in the red. So called the company they said it was mechanical. So for the forum whats my problem and where do I start??? Thanks as Always
goatman1419 is offline
post #2 of 3 (permalink) Old 10-25-2014, 09:36 PM
Dodgefarmer's Avatar
Do you have gauges to check low and high side pressure at the same time?
singles club # 198
Dodgefarmer is offline
post #3 of 3 (permalink) Old 10-27-2014, 12:54 AM Thread Starter
No don't have both gauges. Can get them where do I go from there.????
you think you have problems! 710_burner 7.3L and 6.9 IDI (Pre 1994) 2 11-22-2009 03:45 AM
Still Have Problems HillbillySD 2003-2007 6.0L Power Stroke 6 10-18-2009 10:01 PM
Problems SOOTBANDIT 6.7L Cummins (2007.5-2011) 6 10-14-2009 05:39 PM
Electrical problems/dash problems curtis2003 5.9L Cummins (2003-2007.5) 1 10-21-2006 08:27 AM
Problems lukesdiesel 5.9L Cummins (1998.5-2002) 12 06-06-2006 02:36 AM
