08 3500 Tranny issues - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by gbb, this thread has received 2 replies and been viewed 2573 times.
post #1 of 3 (permalink) Old 02-25-2015, 09:34 PM Thread Starter
gbb
Cool 08 3500 Tranny issues
Have a 2008 3500 which is seldom used. Sits for a month or so at a time. Now all of a sudden tranny won't shift into 5 or 6. Worked for about 20 miles fine then just quit shifting. Never has pulled anything. Tranny appears to be in limp mode all of sudden. No codes appear on Bulldog programmer. Can shift solenoids just stick from sitting. All that has been done recently is I changed thermostat as it had poor heat. We are in a cold climate. Any ideas? Appears electrical to me.
gbb is offline
post #2 of 3 (permalink) Old 02-26-2015, 03:13 AM
ADMIN/MAFIA
neeltburn's Avatar
The 68RFE will not shift into Overdrive until the trans temp is above 100*. You have a tuner, what tune? Did you try returning it to stock and driving it? What was the trans temp while driving? Other than the Bully Dog what is done to the truck? Also what are your driving habits? Loud pedal engaged or grandpa mode? Did you check trans fluid? Also the rocker switch on your shifter, you did not hit that and it display 4th in your shift selector?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 3 (permalink) Old 06-23-2015, 03:42 PM Thread Starter
gbb
Finally got back to Dodge. Tranny issues started after turning a corner. Batteries have a 8-10 A drain. Is there rub spots on wiring harness that are common. faults. Removing tune did not make any change.
gbb is offline
Neighbor's 3500 Transfer Pump Issues BarnOwl 5.9L Cummins (1998.5-2002) 0 11-22-2014 10:42 PM
looking at an 04 3500 worried about tranny wftree 5.9L Cummins (2003-2007.5) 4 12-18-2010 09:50 PM
some issues with my 97 3500 ctkiteboarding 5.9L Cummins 12 Valve (1994-1998.5) 10 04-29-2010 12:47 PM
93 3500 tranny problems whitelightning 6.5L Diesel Engine 4 02-04-2009 04:37 PM
97 3500 ctd stalling issues ctkiteboarding 5.9L Cummins 12 Valve (1994-1998.5) 9 12-09-2006 06:12 PM
